Thinking of buying a 351w from an 1986 Bronco but I cant really find any specs on it. I've heard that pre 72' 351w block are stronger so what can this block handle? Also would it have 2 bolt main caps, if its carb would I be able to switch it to EFI? Any help would be much appreciated. Tryin to build a Single Turbo 96' street/strip car, HP goals 550-650hp. Thanks.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
00' Black GT 2V
BBK Plenum
BBK 75 mm Throtle Body
MGW Short Throw
BBK Long Tube Headers
BBK o/r H
Magnaflow Magnapack Stainless Catback
Spec Stage 3 Clutch
Spec Billet Alluminum Flywheel
H&R SS Lowering Springs
KYB Adjustables
the stock 351w block can handle about 700hp. it should have 2 bolt mains. as for switching to efi i believe that its just a new intake and all electronics and fuel accessories to make it work. if you get a 351w out of a 94 or newer then it is a roller block which might save u some time and money if u go that route
$200 for a complete out of that bronco. . he said that it had an after market cam so wouldn't that lead me to believe that the motor may have been rebuilt before. . .
__________________
00' Black GT 2V
BBK Plenum
MGW Short Throw
BBK o/r H
Spec Stage 3 Clutch
KYB Adjustables
maybe, maybe not.
86 broncos came with 2 different motors, a HO motor which had a four barrel carb and intake, and a non-ho which didnt. My guess is it is an HO motor, an aftermarket cam would only mean that chances are all the gaskets on the upper portion of the engine have been replaced. It is a 2 bolt, non roller motor with the wrong oil pan for a mustang so you will need a swap kit, it is v-belt, has a mechanical fuel pump, and if its anything like mine, pretty ballsy.
__________________
1989 Mustang Lx Sport 25th Ann. Bolt ons. Big Block Swap in Planning.
1979 Ford Bronco, 4 inch lift, 35 a/t 460 + c6 + np205 d44 and 9 inch, debating dana 60/sterling swap.
