Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 351 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-25-2009, 07:46 PM   #1
kremer306
Default where is the best place to get a long block 351
i would like to have around 550 600 hp is that possible and if so where is the best place to get it
__________________
91 vert with 10 pt cage sn 95 brake conversion strange struts currie 9 inch rear end 4.30 gear spooled qa1 rear shocks adj upper lower control arms 306 BLOCK alm heads trick flow upper lower intake trick flow stage 2 cam timing 15 advanced bbk fuel pressure regulator bbk 70 mm throttle body alum. radiator elec. fan msd ingnition.
kremer306 is offline   Reply With Quote
Old 11-06-2009, 08:07 PM   #2
jfritts
1969 Ford Mustang
jfritts's Avatar
Vehicle: 1969 Ford Mustang
id go hit up a junk yard. got mine for 250 but you can find them for cheaper. also if u get a 94+ block its already a hydraulic roller block and its stronger. if you want aftermarket block start checking out summit or jegs or find a local shop on google.
jfritts is offline   Reply With Quote
351, block, blocks, long
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
