Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 351 Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-05-2009, 10:50 AM   #1
bigmike73
Vehicle: 90 gt
Send a message via AIM to bigmike73
Default 351windsor compared to 351cleveland
i want to do a 351 swap into my 90 gt and i have a 351 cleveland out of a 73 mustang. should i rebuild this motor (is it worth it) or should i get a 351 windsor and rebuild that for the swap? What are the differences? Any info would help thanks.
bigmike73 is offline   Reply With Quote
Old 11-05-2009, 11:05 AM   #2
sn95_331_GT_ yellow
1995 Ford Mustang
sn95_331_GT_ yellow's Avatar
Vehicle: 1995 Mustang GT
Send a message via AIM to sn95_331_GT_ yellow
351C > 351W
just know that a cleveland swap is NOT the easiest thing to do.
but worth it.
also, look into building a Clevor.
__________________
Canary Yellow 1995 Mustang GT
had bolt ons: wasnt fast enough, only beat LT1's.
357W build for about 3 weeks (436rwhp 402rwtq) taken out for my Factory Five '33 Hot Rod
baby boy due 20091203, cars kind of on the back burner (he's gonna help build it).
408W carb'd in the works (block and rotating kit already here).
sn95_331_GT_ yellow is offline   Reply With Quote
Old 11-05-2009, 11:19 AM   #3
bigmike73
Vehicle: 90 gt
what is the difference between the swaps? (302efi to 351w carb vs. 302efi to 351c carb i heard the windsor swap was pretty simple) can u use 302 motor mounts for the 351c and with the 302 front accessory brackets bolt up to the 351 cleveland?
Old 11-05-2009, 11:31 AM   #4
bigmike73
Vehicle: 90 gt
how the aftermarket for cleveland parts i heard its a considerable amount more to build a cleveland than a windsor and i'm a college student so money is a factor.
Old 11-05-2009, 03:10 PM   #5
bigmike73
Vehicle: 90 gt
im looking for a real torquey motor which motor can get me more torque mildly built daily driver
Old 11-05-2009, 04:10 PM   #6
wildcobrar
Vehicle: 1990 Mustang Hatch LX
Quote:
If you are a college student and you are on a budget build the Cleveland. Stock 2V Cleveland heads with a blowl tidy up and a good fresh valve job will make and easy 380 HP and 400 Ft lbs with a small cam.
There are swap headers available along with a 351M/400 Truck oil pan and pick up for a 1980 to 1986 F150 will get you hooked up. Stock 302 engine mounts bolt right up and so does the T5, the AOD and the C4 and the C6 for Windsor engines. There are plenty of used 4 Barrel aluminum intakes online for the Cleveland 2V heads. So just a basic rebuild, no after market heads and a set of swap headers and you are good to go. Just use the accessory brackets that cam with the 1973 Cleveland Mustang along with alternator and power steering pump and you are good to go.
I have a 2V headed Cleveland in my 1990 Mustang. Heads are ported. Hyperutectic KB pistons with stock crank and rods. Heddmen hedders and 3 inch exhaust. Promotion T5 straight cut face tooth 5 spd. It runs 10.74 @ 128 MPH on motor only. 9.8 to 1 compression and drive it everywhere. Car weighs 3250 wih driver.
Cleveland swap is crazy easy. No different then dropping in a Windsor.
Joe
__________________
Always in search of faster ET.
]IMAGE][/IMG]
wildcobrar is offline   Reply With Quote
Old 11-06-2009, 12:01 AM   #7
bigmike73
Vehicle: 90 gt
thanks joe if i have any problems ill pm you earlier today i was thinking of selling it and getting a windsor but you convinced me to build the cleveland and be different
Old 11-06-2009, 11:31 PM   #8
wildcobrar
Sure thing, I do not mind helping you. Just send me a message.
Joe
__________________
]IMAGE][/IMG]
Old 11-07-2009, 06:27 PM   #9
wrenchturner75
1988 Ford Mustang
My Garage
wrenchturner75's Avatar
Vehicle: 88lx
cobra pretty much nailed it, it is no harder to drop in a cleveland then to drop a windsor in, you still need the same amount of swap parts, lik a 28 ozflywheel, swap headers and pan, which you would need for a windsor swap also. i also drive mine just about daily weather permitting of course! if you need pics check out my supermotors page itll show ya just how well a cleveland fits, i run power brakes, and a stock hood! a lot has changed since those pics but youll get an idea of how itll look. good luck
__________________
http://www.supermotors.net/20622 351 cleveland powered, nuff said!
wrenchturner75 is offline   Reply With Quote
Old 11-08-2009, 01:50 AM   #10
rmodel65
2nd Amendment Gear Member
rmodel65's Avatar
Vehicle: 1965, ford, mustang fastback
Send a message via AIM to rmodel65 Send a message via MSN to rmodel65 Send a message via Yahoo to rmodel65
they are both the same price www.ausfordparts.com for some 2V closed chamber heads.... what ever you do make sure to replace the valve in the heads they are a 2 piece design and like to come apart at high rpm ask me how i know
__________________
Founder Rmodel's Mustang Militia
“If ye love wealth better than liberty, the tranquillity of servitude than the animating contest of freedom, — go from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains sit lightly upon you, and may posterity forget that ye were our countrymen!”
~Samuel Adams
rmodel65 is offline   Reply With Quote
351, cleveland, location, power, steering
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
