Need Some Quick Bellhousing Help.
k i've been looking at the p/a bellhousing. Now it says it can be used with both pan or case fed transmission. How is this possible? Are the diameters not different in the bellhousing? One bolts up with pump and the other around it? Or is there sumthing i'm not seeing here? Any thoughts?
I told you in a earlier post the bell that bolts to the pump could be used but you will need the longer pump bolts . I said it will look strange but will work. Been there done that. Maybe you did not understand me..
