tfs stage 2 cam
tfs stage 2 cam
so i am about to finish my 351w swap. i have a chance to get a tfs stage 2 cam for 100 bucks. my 351w is a 95 roller block with all stock internals. i have world sr heads and a victor jr intake. i know every one is goin to say i need to check ptv but i just wanted to know if anyone would think that it would fit without ptv issues. so i dont waste my money and then have to get a different cam thanks guys
nobody can tell you if it will clear. your heads may have been decked, the block may have been decked, the pistons could have small reliefs, or ones that aren't deep enough. there are many other factors other than parts selection. Even if the tfs2 doesn't fit, you can just sell it off and not lose anything.
Well, considering the World Sr. heads have a 2.02" intake valve... I'm gonna go ahead and say no. PtV checks will be the only way to know for sure. I strongly suggest that you use the clay method and measure radial clearance. If you already had 2.1" reliefs in the pistons, I'd say you should be good... but stick reliefs are barely over 1.9"
jwog666
12-27-2021 08:09 PM
junior04
09-28-2015 10:53 AM
09-25-2015 09:06 AM
