351 Mustang
351w cam thrust plate roller bearing
Old 04-25-2012, 09:55 AM
Ze2222
Ze2222's Avatar
Default 351w cam thrust plate roller bearing
Hi guys. I have a 351w that im installing a comp cams camshaft thrust plate and roller bearing. I did not get any instructions with it im wondering which side the bearing faces to? Cam gear side or camshaft side? This new thrust plate had a recess cut into and a hole drill in the plate? Hope someone can chime in. Thx
Ze2222 is offline
Old 04-25-2012, 06:44 PM
Ze2222
Ze2222's Avatar
??? No one can help??
Ze2222 is offline
Old 07-25-2012, 11:32 AM
Duncan_GT
Duncan_GT's Avatar
Damn I even tried googling the instructions and didn't find anything. The plate should be pretty obvious to install. The roller bearing ring looks as though it should ride along the groove, so that would make it face outwards, albeit inside the thrust plate. If that makes sense
Duncan_GT is offline
patchshaffer
Tuner Central
10-05-2015 02:24 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
mdg
10-01-2015 07:04 AM
guitarman376
09-30-2015 05:54 PM
Quick Reply: 351w cam thrust plate roller bearing
