351 Mustang
427W AFR225 TRICKFLOW HELP
Old 01-15-2013, 07:43 PM
justwrong
justwrong's Avatar
Default 427W AFR225 TRICKFLOW HELP
hey hoping to set up an anderson PMS and A9L BOX 427W AFR225 TRICKFLOW R 42# INJECTORS 10.6 CR .598 LIFT .252DUR 112 LS. 80mm PROM 75mm tb.does any 1 hav this kinda of setup w real experience for tuning initial startup for a base.would you start w/out pms just a9l box.
justwrong is offline
Old 01-15-2013, 08:05 PM
Duncan_GT
Duncan_GT's Avatar
Is this on a stock block?
Duncan_GT is offline
Old 01-16-2013, 08:04 AM
uedlose
uedlose's Avatar
It may start up on the base A9L it should be close and then in the PMS set it up for 42#inj. you can turn the PMS on at set point to take over the EEC.Then you will probably need to add fuel to it across the board. do you have a wide band? start with idle setup then move up from there.timing should be pretty close also. but if you want you can pull a couple degrees out till you get all the A/F set right. Thats how I started with our EPEC system.
uedlose is offline
Old 01-16-2013, 07:06 PM
Venomantidote95
Venomantidote95's Avatar
It prolly wont start on the 42`s on the stock ecm! It didnt on my buddies 347 with 42`s on the stock ecm had to use a set of 30`s until he got his tuning setup.
BUT that kinda cuin may start fine idk!
Venomantidote95 is offline
MasterLanMan
21
09-16-2015 03:26 PM
91LXstanger
03-23-2005 11:10 PM
RR69
02-10-2005 05:38 PM
67coupe
02-04-2005 12:37 AM
1865mustang
07-04-2004 10:01 PM
Quick Reply: 427W AFR225 TRICKFLOW HELP
