400hp 351w N/A - Page 2 - MustangForums.com
Old 07-25-2013, 05:19 AM   #11
95 BLOWN GT
95 BLOWN GT's Avatar
+1 I was thinking the same thing..
95 BLOWN GT is offline   Reply With Quote
Old 07-25-2013, 05:23 AM   #12
95 BLOWN GT
Quote:
Originally Posted by Duncan_GT View Post
I love the valve covers for some reason lol
thanks..they are cast aluminum..they were clear anadized that had the an fitting welded on later for an evac system..it messed up the finish a little so i had a black crinkle powdercoat applied to them...needed something tall to clear the t&d shaft mount system.
Old 07-26-2013, 06:08 AM   #13
Blackfox3332
Found what out? That it'll make 400 hp? How do you know when it isn't even built yet?
So true but when the machinist and vendor boasts the same, and the crazy dough i had invested in thus far not in just parts but in the machining side of things along with weeks of researching.... I kind of already know what the end result be.
Blackfox3332 is offline   Reply With Quote
Old 07-26-2013, 11:51 AM   #14
Duncan_GT
Duncan_GT's Avatar
Quote:
So if the vendor and machinist say it'll make 700, are you going to believe that too? Does what you researched have credentials?
Duncan_GT is offline   Reply With Quote
Old 07-26-2013, 06:18 PM   #15
89fiveeight
89fiveeight's Avatar
I'm gonna go out on a limb and say its all just spoken word.
89fiveeight is offline   Reply With Quote
Old 08-30-2013, 09:29 AM   #16
95 BLOWN GT
I am going to agree with you....taking my car to get dyno tuned next tuesday..i will post results in one of these threads.
Old 12-26-2013, 07:38 AM   #17
aode08
The 351w is a torque maker for trucks.It will do 400hp, but here are the secrets from my engine builder.
If you want to make power, you have to buy light internals,high compression pistons for your heads ,headers,heads,cam, intake, cold air intake.
The next trick is proper lifter rod alignemt, most folks get them too short or too long, and just go cranking the nuts down, dont do that, look up the procedure and get an adjustable lifter pushrod for your application, as this casuses binding and robs over 40+HP.
The next trick is when you have the engine honed MAKE SURE THEY USE BLOCK PLATES,AND THE BLOCK IS WARM TO THE TOUCH WHEN DOING SO-RIGHT OUT THE HOT TANK, FAILURE TO DO SO WILL CAUSE BORE DISTORTION and over 30+HP, more when the car is warm.
The final is use light oil and oil pan scraper/or whatever you call it get oil off the crank.
Its the stuck the naked eye does not see, that always bite you in the rear at the dyno and leave you stumped after you spent all that money.
aode08 is offline   Reply With Quote
Old 06-02-2014, 07:46 AM   #18
Venomantidote95
Venomantidote95's Avatar
A 351cube w is a turd and won't make 400hp without around 11.5:1 compression na no matter the hci.
Venomantidote95 is offline   Reply With Quote
Old 07-05-2014, 04:16 PM   #19
84CopperGT
84CopperGT's Avatar
Quote:
Yeah they will actually. There was an article where they took a junkyard 351w, cleaned it up, new heads, cam and bolt ons. then they made 450 NA. then they twin turboed it and made over a 1000 on stock internals. that was at the crank.
84CopperGT is offline   Reply With Quote
Old 07-05-2014, 04:26 PM   #20
bluebeastsrt
bluebeastsrt's Avatar
1000........ Stock block and internals........I don't think so.........
bluebeastsrt is offline   Reply With Quote
4r70w torque converter q's guitarman376 4.6L (1996-2004 Modular) Mustang 0 09-30-2015 05:54 PM
Electric fuel pump trouble LiquidDrink Classic Mustangs (Tech) 8 09-29-2015 10:06 AM
EFI into Carb Jacob4589 5.0L (1979-1995) Mustang 3 08-08-2015 11:00 AM
351w stroked to 427 619socalstang 5.0L (1979-1995) Mustang 47 05-17-2007 09:55 PM
PARTS FOR SALE WNDSOR Parts For Sale 5 01-30-2004 09:47 AM
