351 Mustang
414 build.....
Old 06-01-2014, 11:08 PM
Venomantidote95
Venomantidote95's Avatar
Default 414 build.....
I'm currently going from my 347 to a 414cuin Windsor. I have as follows 71w block Afr205 heads trick flow cam edelbrock victor intake 42lb inj c&l 76mm induction to a 75mm tb 1.7 RR dart 4bm caps eagle rods and 4in crank aeromotive e700 pump 10 supply from pump to reg 8 from reg to rails 6 return. I'm usi g the bbk 1 3/4 in ceramic longtubes thru xpipe with dynomax ultras. Still running the 3.55s went from Aod to c4 have moated 1/4 horse setup. I'm running a 22cc dish to tailor the compression to a hair under 11:1. Pump gas motor here with my NX Gemini kit using custom PTC nitrous converter aluminum driveshaft. About 60% done swapping to upr coilovers and km ember on the suspension. Will post results on the dyno when I'm done....hopefully before this year is out.
Venomantidote95 is offline
Old 06-02-2014, 10:40 AM
bluebeastsrt
bluebeastsrt's Avatar
Good luck with the build.
bluebeastsrt is offline
Old 06-02-2014, 12:24 PM
Venomantidote95
Been long and slow.... changed my mind a couple times on some stuff but its finally coming together.
Old 06-02-2014, 06:21 PM
bluebeastsrt
I feel ya. I'm easily 2 years into this build but fordstrokers should have my engine built in a few months and that's the final piece of the puzzle.
Old 06-02-2014, 08:23 PM
Venomantidote95
I still have to build my c4 I'm using all PA components using the upgraded drum,servo and roller planet.... money has just been slow lol. Wanted to go up to a 432 but funds just weren't there the heads were not a fun buy either lol but its my first set of fully CNC heads wow.... worth the money to look at them. But layer when I have time I'll try to post some pics.
Old 06-03-2014, 11:12 AM
bluebeastsrt
I can only imagine what those cost. I just resprung my TF 190s and used them for this build. They flow good and I plan to make up for the lack of cubes with a healthy shot of N2o. What kind of power are you looking at for that motor?
Old 06-03-2014, 12:23 PM
Venomantidote95
Shooting for around 500 na. I also have my NX kit for the extra I don't make.
The only thing I'm iffy about is the tb but I have talked to many different sources and actually had it flowed on a sf600 it flows 830 cfm in our atmosphere here so maybe its good to go.
Old 07-26-2014, 04:04 AM
84CopperGT
84CopperGT's Avatar
From talking to a few builders for my own build you should hit 500 to the wheels. my buddy has a 71 Mustang with a 393 stroker and it makes just under 500 with 10.5 compression NA.
84CopperGT is offline
Old 07-26-2014, 09:56 AM
Duncan_GT
Duncan_GT's Avatar
Need a bigger TB/MAF combo. My 393 sports 90mm stuff
Duncan_GT is offline
KP Racing
05-15-2013 09:33 AM
Tryingtofindone!
03-21-2013 10:20 AM
Psustu
05-16-2011 06:50 PM
flewbyu
08-13-2007 08:58 AM
90mustang5.8
05-23-2007 08:29 PM
Quick Reply: 414 build.....
