engine swap 302 to 351 - MustangForums.com
Old 07-23-2014, 10:12 PM   #1
claysstang@att.net
Default engine swap 302 to 351
i have a 88 302 that im going to swap a 351w into i know i will need a oil pan n pick up. could the intake off of the 302 work on the 351w fuel injection manifold
work.how about the dist. also what would be a good cam??? with 351 bore 030. stock heads maybe something different, would like to get about 425 hp/ 450 trq.
going to run 410 gears
claysstang@att.net is offline   Reply With Quote
Old 08-28-2014, 03:11 PM   #2
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
No your intake manifold will not swap and no your distributor will not swap over either. They are 351w specific.
fastbackford351 is offline   Reply With Quote
Old 02-04-2015, 12:38 PM   #3
95 BLOWN GT
95 BLOWN GT's Avatar
stock heads ? why
95 BLOWN GT is offline   Reply With Quote
Old 02-11-2015, 07:13 AM   #4
Venomantidote95
Venomantidote95's Avatar
You can use your 302 distributor lol. The intake no. Stock heads why?
Venomantidote95 is offline   Reply With Quote
Old 02-24-2015, 02:02 PM   #5
im_stuck_in_iraq
im_stuck_in_iraq's Avatar
I was told to go with AFR. Prob 220.
im_stuck_in_iraq is offline   Reply With Quote
Old 03-06-2015, 08:17 AM   #6
fastbackford351
Foghorn Leghorn
Quote:
Wrong. The oil pump drive shafts are different sizes between the 302 & 351w.
Old 03-09-2015, 09:25 PM   #7
rmodel65
Yukon Cornelius
rmodel65's Avatar
no way youre getting 425hp with stock heads...
personally id get a 94+ f150/e150 351w motor they are setup for roller cams. as for the oil pan if i remember correctly the crown vic 351w oil pan will work. probably the dizzy too if you can find one that came with the sefi injection(but i dunno what year they stopped using the 351w in the vics?)
rmodel65 is offline   Reply With Quote
EFI to CARB conversion problem, running like a PIG..vacuum problem? YoungStangsMan 5.0L (1979-1995) Mustang 15 09-05-2015 08:01 PM
Can a 351 be put in a 68 Mustang ? Mustangs of Illinois Classic Mustangs (Tech) 4 08-22-2015 11:00 PM
engine swap 69 classic69FB Motor Swap Section 1 08-13-2015 12:58 AM
EFI into Carb Jacob4589 5.0L (1979-1995) Mustang 3 08-08-2015 12:00 PM
