price check plz
price check plz
any1 who ahs done the swap into a fox have a rough esti on the cost of everything they had to buy, i would need a tranny (its old) i would like a efi 351\
any help in this would be nice
ty
ty
RE: price check plz
im just looking for a 351 in there maybe some heads later on
i would like efi but carb would be ok but i have no experiance with carbs
it will be mostly street and nothing over 400hp i have no need for anything more
i was thingking longtubes, intake mani and heads and a cam
RE: price check plz
Well if you go with EFI than you are going to need to upgrade your fuel system (injectors, pump, etc.) Also, you might want to consider upgrading your ignition (box, coil, distributer, wires). Now you said that you were thinking long tubes. For ex: I paid 350 for my MAC LT's. Intake manifold, atleast 400-600. Heads really depends on what brand/size. They can range from $850-1600 for nice street heads. And cam $150-300. Than little things like motor mounts, gaskets, and all the little things in between. If I were you this is what I would do.
Fuel- Injectors, Fuel Pump.
Ignition- MSD Ignition box, MSD Blaster Coil, MSD Pro-Billet Distributer, MSD Ignition wires (or FRPP)
Heads- AFR 185 or 205's
Cam- Custom Grind from Comp (its really worth it)
Manifold- Edelbrock RPM II U & L
Suspension- Stuts, shocks, subframe connectors, upper/lower control arms, etc.
Rear- Limited slip, Strange 3:73's, Strange axles.
Cooling- Electric water pump, nice radiator
Im sure you get the point. You can keep it cheap or you can go all out. You dont NEED everything here but it wouldnt be a bad idea. Im sure someone would like to shed some more light....
Also, learn about carbs and carb it
RE: price check plz
ORIGINAL: 88BlueGT
RE: price check plz
Aye, Carbed is more user freindly for the driveway tuner. Although with all that wires more power can be found, but it costs ALOT more, and is ALOT bigger headache. Carb is more fun, but EFI can have higher power.
