Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.0L V6 Specific General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-06-2009, 06:41 PM   #11
Sancho805
Sancho805's Avatar
Vehicle: 2006 Ford Mustang
its most likely the ipod harness causing the problem. it may not be truly compatible even though it seems to work fine at times. i had the same issue a while back with an older ipod adapter unit. after much research, i finally found a unit that does not throw off my ECU.
__________________
'06 4.0 Stang :: Auto :: 3.73/T-Lok :: Aluminum D/S :: C&L Intake :: Bama Tuned
JBA H-Pipe Dual Exhaust :: JBA Shorty Headers :: GT Anti-Sway Bars w/ Poly Bushings
Sancho805 is offline   Reply With Quote
Old 07-08-2009, 07:43 AM   #12
bdickens63
Vehicle: 2006 Mustang, 4.0
Default Ipod Harness
What unit do you have and where did you get it. I got my mine at Best Buy.
bdickens63 is offline   Reply With Quote
Old 07-08-2009, 04:30 PM   #13
mrfish
Vehicle: 05 Mustang Convertible
Default ipod
Yes, please tell us what ipod interface does NOT cause these problems.
mrfish is offline   Reply With Quote
Old 07-08-2009, 05:54 PM   #14
Sancho805
Sancho805's Avatar
i got my iSimple at Best Buy also but heard that the first wave of iSimple units didnt work either. my unit that i have now is #ISFD73. i've had no issues with the ECU since i installed the adapter almost 7 months ago.
__________________
Old 07-09-2009, 06:55 PM   #15
hataap
Sancho is right, its probably the unit. I didn't get those error messages until I installed my iPod Adapter. Sancho, how do you like the whole iSimple interface? Is it similar to the others in that you can control everything through the head unit??
__________________
06 Auto V6 Mustang, Tungsten Grey
Pony Package - FRPP Exhaust - K&N Intake - SCT XCal2 - Bama Tunes - PIE iPod Adapter
hataap is offline   Reply With Quote
Old 07-20-2009, 03:14 AM   #16
Kaisoboy
Kaisoboy's Avatar
Vehicle: 2005 Mustang GT
Well...I have the new iSimple, #ISFD73 unit and on occasion it messes with my gauges. I installed this about 5 months ago and before buying it I phoned Peripheral and asked if they solved the problems and they said they were resolved. NOT! Now it does not happen very often but it happened again yesterday and it seems once I shut the car down and leave it overnight it seems to reset itself. I do not require disconnecting the battery. However I noticed on there site they had a new revision last night and I installed the firmware this morning (Rev .39G) or something like that. So the battery was disconnected this morning which should reset everything in the car and the iSimple has a new firmware revision in it. I will post if I have the problem reoccur.
cheers
__________________
IT'S GONNA BE A STANGPEDE
2005 Mustang GT, Satin Silver Matalic, 4.6 L (281 ci) V8, Black Leather interior, 5 speed, K&N FIKP CAI, Flowmaster A/T Axle backs, 6" shorty, FRPP Strut Bar, DiabloSport Tuner, Bamachip 91 race tune, CDC classic chin spoiler, Roush Hood scoop, Tinted (35% up Front, 20% out back), B&M sport Shifter, Roush classic shifter ball - Black, Rear Honeycomb Blackout Panel, iPod integration, Sequential Tail Lights
Kaisoboy is offline   Reply With Quote
Old 07-20-2009, 08:23 AM   #17
kn0x`
Vehicle: 2005 Ford Mustang
I have the same problem...sometimes when I start my car, my gas reads E or totally full past the point of the Full mark. About 5-6 months ago, my battery died and I changed that out, ever since then, my tune sometimes works when I start my car and sometimes it doesn't work. Now the fuel sensor doesn't work???? What should I do? If I go to the stealership, should I retune to stock or tell them I have a tune?
Please help...
__________________
2005 Vista Blue V6 Mustang; 5 Speed Manual
Mods:
Custom Dual Exhaust w/ American Thunders, C&L CAI w/ SCT3 and Bamachips Tunes, Saleen S Style Chrome 18in., Eibach Pro-Kit, GT Front Brake System, 15% Tint, 4.0 Emblem.
kn0x` is offline   Reply With Quote
Old 07-20-2009, 10:46 AM   #18
Kaisoboy
Kaisoboy's Avatar
Quote:
Please help...
Do you have a iPod Intergration system? If you don't it would appear that you have a underlying problem. First I would retune the car to stock to see if it is indeed the tune causing the problem. If you do not have the problems re-occur with the OEM tune then you know it is the Bamma tune. Now if your fuel sensor still does not work there is a TSB for that. Before I installed my iPod Intergration I also had a fuel guage sweeping problem and Ford fixed that free of charge because of the TSB. They replaced the fuel sensor in the gas tank. If you do take the car to the Dealer, YES I WOULD FLASH IT BACK TO STOCK just in case they decide to flash the car. I always return my tune back to stock when taking it to the dealer. It will save you a lot of hassles in the end.
__________________
Old 07-20-2009, 03:43 PM   #19
Sancho805
Sancho805's Avatar
Quote:
cheers
did you confirm your dip switch settings are correct?
__________________
Old 07-20-2009, 03:50 PM   #20
Sancho805
Sancho805's Avatar
Quote:
yes, i can control through the HU but i HIGHLY recommend taking some time and building playlists for what you listen to the most for faster searching. navigating by artist name or album name takes A LOT of patience to scroll through if you got a big library. other than that, its been great.
__________________
2005, 2006, car, check, code, data, dte, dteerror2005ford, engine, err, error, fli, ford, fuel, gt, mustang
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
