In your other post didn't you say you have a custom dyno tune? If so that is low; if that's the tune that came with it that's about right, Doug's mailorder tunes are pretty conservative (very safe) What was your afr? Probably pretty rich. Mine is a manual and with a custom tune got 287hp and 301 torque.
__________________
X Charger Hi Po kit#21, 5 speed manual, Hurst shifter,T-Lock/410's, GT takeoff kit, Bullit grill, dual exhaust, Eibach springs, front/rear swaybars, Tokico D Specs, staggered black bullits.
For the Bama tune that is pretty much right. Before my custom tune mine dynoed at 26ish and now it is at 271. Don't read too much into dyno #'s, as nearly every dyno is calibrated just a little different. Was it a Mustang dyno, because if so those always calculate a lower number than a dynojet. Need more info man.
