i just installed the xcharger on my car and when i started it it sounded like someone is screaming and also it sounded like i got cams anyone knows what it is thx for help
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
2005 legend lime convertible,MAC dual ss catback,HIPO plus X-Charger,4:10 ford racing gears and t-lock,LED tail lights,gt500 spoiler,hood pins,18" deep dish rims,Pioneer D3 gps,Z front grill,duals 6000k HID lights,,and much much more ...
well mine is sitting in the boxes under my desk as I type this but if the scream is real loud id say its an vac leak.
as for sounding like its cam'd up ,, it does switch the plugs around so id say that has something to do with it and would not worry
__________________
X-Charger #66 in and singing
MMMWWWEEEEEEEEEE!
Yeah I had a vacuum leak on mine. I had a high pitched squeal that disappeared when I would rev the engine but return once I let off the throttle and the revs lowered to idle. the noise also persisted at idle. I also was throwing lean codes on my 02 sensors, which makes sense. I did the little pvc pipe trick (3-4 ft long tube used as a stethescope to hear where the leak was coming from the loudest). There was that one screw on the back of the blower that I had forgotten to tighten during the install. I sprayed some carb cleaner at it and the engine rpms shuddered and the squeal went away. When I turned it back on it came back and I sprayed the carb cleaner again and got the same result. I then tightened the bolt and everything has been running great ever since.
yea that is what i have it sounds like its somewhere in the back of the engine and every time i spray itthere rpmsjump but then after like 3 sec the car sounds like its gonna die it got 2 be a big air leak or something maybe gasket is not good
what you guys think the other sound is the one that sounds like i got drag racing car ?
thx for help
__________________
yea its all done and works perfect now we had a gasket leak so we fixed that and we had EGR tube problem but its fixed as well i am so happy with the xcharger and love the WWWWHHHHEEEEEEEEE thx all for help
__________________
what pulley do you have..... how did you fix the leak? I had one, and was able to fix it by spraying a bunch of carb cleaner in where the leak was, and it silenced it and it never came back. I think the gasket soaked some up and when it dryed, it dryed a little thicker, or stuck to the metal... anyway the vac leak was gone.
i had 2 take the blower off the car and reinstall it all over again i called Dave and he send me a new gasket and EGR tube and that was it we installed it and it was perfect
ooo man i just love it the TQ is sick i cant wait for July 18 i am gonna Dyno tune it
__________________
