Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.0L V6 Specific General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-24-2008, 05:31 AM   #1
mustangpogi
Default ? Lowering spring with stock shock and strut
? for those that lowered there mustang with stock shock and strut.
1. How long before you have to replace your shock and stock?
2. What lowering springs did you use?
3.What brand of springs is better for stock shock and strut?
I was thinking of buying this combo or just buy the springs. i have 20" wheels from AM.
a. Ford Racing N Performance Springs
b. Total Tokico Front & Rear Strut/Shock Package
Thanks.
mustangpogi is offline   Reply With Quote
Old 11-24-2008, 10:02 AM   #2
ODDYSEY
4.0L Section Moderator
2007 Ford Mustang
ODDYSEY's Avatar
I put the FRPP N Springs on my car with stock shocks/struts. It was fine for a while.. but since my rear tires have a larger offset (staggered), I got the Tokico D-Specs for the rear so my tires wouldn't rub against the fender.
Since I put the tokico's on the rear, it seems like my front is really bouncy, and I will be putting the tokico's on the front as soon as I can.
The FRPP springs worked out great for me, I would recommend them.
__________________
V6 of Fury! - X-Charger #101 - HI-PO Plus 2.8 | FRPP GTA's | FRPP 3.73 & T-Lok | FRPP springs | Tokico D-Specs | BMR Panhard | Razors - 18x9 | Nitto 555's | Auto Meter - Nexus gauges | Shaftmasters aluminum driveshaft | TCI ratchet shifter | Moroso tanks | UPR catch can | and more...
Click here to view the V6 of Fury!
ODDYSEY is offline   Reply With Quote
Old 11-24-2008, 10:09 AM   #3
mustangpogi
Thanks ODDYSEY, D-Specs is out of my budget so I will go with TOKICO HP, $200 cheaper. i also have staggered set too. 20x8.5 and 20x10.
Old 11-25-2008, 09:36 AM   #4
mustangpogi
I guess nobody here lowered there Mustang !!!!
Old 11-25-2008, 12:42 PM   #5
thuxel
thuxel's Avatar
I got the Eibach Pro Kit with stock shocks and struts.
I want to get the Tokico D-Specs once I get enough $$$$$$$$$!
Before and after.
__________________
2007 V6 S&B CAI, BAMA 91 Perfomance Tune, Pypes True Dual Exhaust, Liquid Metal Venom 18" Wheels, Eibach Pro Kit,GT Sway Bars, GT Bumper, Granatelli Coil Pack & 0 ohm wires
thuxel is offline   Reply With Quote
Old 11-25-2008, 12:55 PM   #6
scorpio333
scorpio333's Avatar
I went with Roush springs in the rear. The stock shocks lasted a week before I couldn't take it anymore. Added Roush shocks in the rear, it's about a month later and those are destined to end up in the pile of used parts. Considering both d specs and Koni.
__________________
scorpio333 is offline   Reply With Quote
Old 11-25-2008, 02:02 PM   #7
ODDYSEY
2007 Ford Mustang
ODDYSEY's Avatar
Quote:
Go with the D-Specs, you won't regret it.
__________________
Old 11-25-2008, 05:25 PM   #8
So_Cali
2006 Ford Mustang
So_Cali's Avatar
Vehicle: 2006 Ford Mustang
Eibach Pro-Kit and the FRPP N's are almost the same if not mistaken...Anyhow I went with the Pro-Kit and Tokico HPs, I'm sure D-Specs are great but, outta my range and didnt care for the adjustability. If you're gonna change the Springs out, you're much better off doing the struts/shocks as well.
__________________
S197 Sized Sig--I Haz It...Thanks Xeno!
2006 Performance White V6
More Show Than Go
Roush CAI BAMA Tuned
Retro-Solutions 8K 35w HID Kit
Staggered 18" Bullitts w/ NITTO 555's
Web-Electrics Sequentials
Eibach Pro-Kit
Tokico HP Gas Shocks
Ninosport Dual Conversion w/GTB's
GT Takeoff Rear Swaybar w/Prothane Poly Bushings
"California Made It Happen"
So_Cali is offline   Reply With Quote
Old 11-25-2008, 05:40 PM   #9
BigGameHunter589
2006 Ford Mustang
Vehicle: 06 Pony
I'd definitely do both at the same time if your a do-it-yourself-er. it'll make life alot easier!
__________________
Evolution Performance Tuned, Xpipe w/ magnaflows
C&L CAI, Front/Rear Sways, Strut Tower Bar,
GT sideskirts, OEM Hood Scoop, Isimple Adapter.
BigGameHunter589 is offline   Reply With Quote
Old 11-25-2008, 05:53 PM   #10
mustangpogi
Thank you for the response. I think I will go with my original plan.
Tokico HP Front & Rear Strut/Shock
There's a group buy for D-spec in this site if anyone interested.
http://forums.bradbarnett.net/showthread.php?t=475088
combination, forum, mustang, shock, spring
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
