Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.0L V6 Specific General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 01-08-2009, 02:40 PM   #1
red07Pony
red07Pony's Avatar
Default brakes locking up???
I was wondering if anyone else has experienced anything like this??
My car is a 2007 and I live in Ohio where the temperatures have gotten pretty cold recently. My car sits outside (no garage) and is my daily driver. In the mornings I've noticed the car feeling really slugish like it doesn't want to move and only really noticed it on the really cold mornings(teens or 20s) when I go to back up it is hard to get moving and I have to gas it to get it to move. Then once I back up it almost stops on it's own. As I drive it tends to "free up" until it is no longer noticable.
This morning was an exception where it took almost my whole ride to work (@ .5 hour) to free up. I've tried pulling up and down on the e-brake several times but that didn't seem to have any affect. Also during my ride into work I started putting 2 and 2 together and realized my gas mileage has really dropped recently as well and I'm wondering if the brakes are riding and could be the cause of both problems.
I took it into the dealership this morning to have them look over the brakes. I'll see what they have to say.
Anybody else experience anything like this?
__________________
Pony Package (MT-drive, don't ride), Trunk blackout panel, side louvers, superstripe, K&N filter, Borla Stinger (single for now...)
http://s229.photobucket.com/albums/ee110/red07Pony/
red07Pony is offline   Reply With Quote
Old 01-08-2009, 02:53 PM   #2
GrayPony
Your emergency brake cable is getting moisture inside and freezing... it's a known problem. Take your car to the dealer and have them fix it under warranty. There is a TSB on the fix
__________________
GrayPony is offline   Reply With Quote
Old 01-08-2009, 06:00 PM   #3
red07Pony
red07Pony's Avatar
Thanks for the info GrayPony.
I just got it back from the dealership and they said they checked out the brakes and of course everything looked good. I know I'm not off my rocker so I'm going to look into that TSB. I thought there used to be a menu option for recalls and tsb's on this site but I can't find it anymore. Who knows where I find that info??
Thanks
__________________
Old 01-08-2009, 06:10 PM   #4
28HopUp
MF Administrator
1985 Ford Mustang
28HopUp's Avatar
Vehicle: Classic SSP S197
Send a message via AIM to 28HopUp
You're right. The TSB's have gone MIA. I'll ask around to see if we can dig that thread up.
__________________
1985 SSP Mustang - California Highway Patrol Unit #E408395
We are the music makers, and we are the dreamers of dreams - Willie Wonka
28HopUp is offline   Reply With Quote
Old 01-08-2009, 06:29 PM   #5
red07Pony
red07Pony's Avatar
Well I googled for tsb's and found TSB 06-05-04 for freezing parking brake.
"Some 2005-2006 Mustangs built prior to 10/1/2005
may exhibit park brake cables that freeze in cold
weather due to water intrusion, and subsequently
not release.
The problem is mine is a 2007.....
__________________
Old 01-08-2009, 06:48 PM   #6
jpac
Vehicle: 2005 Ford Mustang
I had the same problem a few years ago. The situation you described was mine, almost exactly. I took it to the stealership and they had it for a week (not sure if there was a tsb for it yet) and all is good now. I would say that just because they (Ford) know the problem exists doesn't mean that they fixed it. If I remember correctly, there is a rubber boot covering the cable and it was split open. I would check that first...def. do not drive until you git it figured out though. Good luck
jpac is offline   Reply With Quote
Old 01-08-2009, 06:53 PM   #7
06 Gt on 20s
Vehicle: 2006 Ford Mustang Gt
It happened to me too, a few weeks ago it kept stalling when backing up and then once i got it going it seemed fine but when i stopped a few mintues later the right rear brake was really hot and smelled like it was burning, i drove home and it seemed to go away and i stopped using the e-brake and now i keep it in 1st when parking and havent had a prolem yet.
06 Gt on 20s is offline   Reply With Quote
Old 01-09-2009, 01:32 AM   #8
my first mustang
Vehicle: 2005 V6
I had this same problem over 38 years ago on my 71 Roadrunner. I've also had the same thing happen on my antique 35 Dodge 15 years ago(a brake drum on the back of the transmission)so it doesn't matter how old or new the car is. All you need is a little water or slush to get in the cable and the emergency brake will freeze. I learned not to use the emergency brake and just leave the car in gear when the temp. gets below freezing. Driving the car before the emergency brake releases can cause damage to the rear brakes.
__________________
White 2005 V6 coupe w/automatic. FRPP M5230V6 dual exhaust. VMP cai w/VMP 93 mileage tune. Shaftmasters 4 in. aluminum driveshaft. 8.8 T-Lok w/3.55s. 17x8 in. black FRPP Bullitts w/Pirelli 235-55s. 14.65@93.58
my first mustang is offline   Reply With Quote
Old 01-09-2009, 09:17 AM   #9
28HopUp
MF Administrator
1985 Ford Mustang
28HopUp's Avatar
I found this thread, which mentions the same TSB number in post #7 -
http://mustangforums.com/forum/2005-...-freezing.html
__________________
Old 01-09-2009, 03:53 PM   #10
red07Pony
red07Pony's Avatar
Thanks for finding that thread. I called the dealership back and he said they checked the e-brake cable and everything looked ok. His comment to the tsb was that it wasn't for the '07 because Ford obviously made a production change to fix that problem.
I guess I'll do what the other owner(s) did and if it happens again, stop the car and call roadside assistance and have them tow it in. He left it up to me if I wanted to leave it overnight tonight and we are supposed to get some freezing rain/snow so I might drive it there in the crap and leave it there for them overnight if it's not too bad. We'll see.......
__________________
060504, brake, brakes, cable, freezing, locking, mustang, park, tsb
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
