I have 18" OEM rims with V6 brakes...no issues at all. Not sure where you heard that...but it is not the case.
Its a known issue on the forum.
There are manyposts about 18" OEM rims on a V6.
See the pic above of the V6 with 18x8.5s on it.
The clearance is dangerously close unlike the
16x7 and the 17x8 clearances.
__________________
NON PUMKIN JACKER
Quote:
Originally Posted by Boozshey
Oh yeah, I forgot Norm was God on here.
Give me a break!!!
Quote:
Originally Posted by Norm Peterson
<rises to the bait>
. . . Definitely not God.
Norm
That is just my point. Threads get started and people comment (not directed at you) about items they have no personal experience with. It cannot be a known issues on the forum as the issue does not exist.
Being "close" or "dangerously close" is meaningless. The wheels fit. What is the difference between 1/4" of clearance and 1/2" of clearance (I know...a 1/4")...but seriously...nothing moves here...so why worry.
The proof is in my sig. 18" OEM wheels with V6 brakes. No issues. No worries.
No, you won't need the calipers. All you need are the new caliper mounts (which relocate your stock calipers further from the hub of the rotor to accommodate the larger rotor size) and some GT Takeoff rotors.
If you look hard enough you can find some good deals. Exhaust your options! Craiglist...ebay...MF classifieds and others...
How much do the mounts run?
__________________
2007 SS Mustang V6 Premium
Gray Leather Interior, Manual, V6 PP, Interior Upgrade Package, 35/20 Tint, 14inch Shorty Antenna, Silver 17" Bullitts, GT Spoiler, GT M/T Muffler, CF dash, SR Window Louvers, Roush Retro Knob, Magnetic Blackout Panel, Bullitt Style Fuel Door, Shaker 500, And Some Sweet Mustang Floor Mats! Also had a Carbon Creations OEM CF Hood with Roush Louvers but they went up in flames along with my house on Nov. 4th 2008
So nobody has rotors from brakemotive? OEM rotors from dealer $500. Not going there!
I'll sell you mine when i go to GT brakes!? Haha.
__________________
I have Bullitt take offs with the V6 rotor/bracket combo as well. In my case there was an interference issue. I just ground the bracket down and test fitted until there was no longer an issue.
The second pic 157db posted shows the critical area for anyone contempating this upgrade.
I also have the 18" bullitts on a V6 with V6 brake caliper
mounting brackets and the clearance is paper thin.
Any wear is the front spindle bearings and there will be issues.
No worries??
I also would not advise grinding anything off of the caliper
bracket to fix clearance issues. The brackets are coated
with an anti rust coating and it was removed when the grinding
was done. It also weakens the cast caliper bracket.
__________________
NON PUMKIN JACKER
Give me a break!!!
<rises to the bait>
Norm
wear in the spindle bearing? The wheel, brake caliper and rotor cant move independently
go look at your car or any car. This is also how known issue start. People make mistake and lead others to think its an issue.
No worries??
OP are u sure u need 2 change the rotors and not just the pads... how many miles on ur car if u dont mind me asking?
__________________
STANGPEDE MEMBER - LOS ANGELES CHAPTER
Quote:
Originally Posted by Acer2428
1) Watching porn is not depressing.
2) ... Falling asleep while watching porn is depressing.
But then you wake up and you're watching porn, so see rule #1
Quote:
Originally Posted by Stang_Heritage07
I compensate for my small penis and lack of friends w/ a gigantic TV
