Ok I have gone through and gathered all the items listed to install the x-charger, but I am having some issues with a few things.
Torx T20 socket or bit - Dave mentioned on certain 07 models this isn't needed?
Torx T30 socket or bit - Dave mentioned on certain 07 models this isn't needed?
E8 inverted Torx socket - I think this falls under the same category as above?
1 1/16 crowfoot wrench - I checked 5 places and couldn't find this, is it really needed?
teflon paste thread sealer (Permatex 80632) - I remember seeing where someone says this is terrible and just get the teflon tape?
trim adhesive (3m 08031) - can't seem to find this either....
Suggestions on any of the above? X arrives tomorrow and I have setup an install party for Saturday, we will take pictures and video, but not sure if we will be as cool as afixer to do a webcast :P
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
V6 of Fury! - X-Charger #101 - HI-PO Plus 2.8 | FRPP GTA's | FRPP 3.73 & T-Lok | FRPP springs | Tokico D-Specs | BMR Panhard | Razors - 18x9 | Nitto 555's | Auto Meter - Nexus gauges | Shaftmasters aluminum driveshaft | TCI ratchet shifter | Moroso tanks | UPR catch can | and more...
i used 77 spray glue instead of weather strip ad - home depot
teflon paste home depo also has
you can get a torx set cheap you will also need a large allen for the plugs. and you can do the egr with a wrench but i had to grind mine off.
__________________
Progress Group, full adjustable front Aluminum Struts and rear suspension system, Adjustable LCA's & Panard Bar.Rear adjustable shocks Rotor Pros drilled and slotted (GT front) and rear Rotors - Yellow Calipers Cali Special rear bumper,CDC front Chin, MGW interior, Midwestern tower, mirror & radiator side covers, Street Scene Center Light Grill, and much more than they will let me post!
you need one of the torx bits to get the MAF out of the housing, dont remember which size. torx bits are common, get them from any hardware store.
i *thought* the e8 inverted was optional, iirc it was for a stud on the alternator that i didnt have. i will consult my manual when i get home, you should be able to figure out if you need it or not. i bought a whole set from sears, and it was expensive for something i will never use.
crowsfoot can be purchased online from sears, i didnt find an actual store that carried one. think it was like 28 dollars.
i used teflon tape.
i used spray glue.
__________________ 2007 torch red premium v6 pony package
X-Charger #75
use the spray glue on one side of the gaskets to hold them in place. the crows foot is not a must . it can be done it just makes it easier thats all.
__________________
a heck of a lot easier. You could clean your garage floor with a toothbrush too, but it's not much fun without a proper tool. I'd shell out for the crowsfoot.
+1 to torch vert, i had a BEAR of a time getting the EGR valve off even WITH the crowsfoot. wouldnt want to do it without it. might consider putting anti seize on the threads before you put the new one on.
X-Charger #75
Nothing to offer, but please take pics......lots of them. After the install, I'd like to come over and see your car. I'm really contemplating doing the same. That or the Powerhouse Turbo setup.....can't decide. Good luck!
__________________ '06 S197 V6 w/5-speed & Pony Package w/ GT Front End/ FRPP Lowering Springs/X-Pipe /FRPP GTA's '98 SN95 V6 w/Auto My other toy
No problem! The pictures have started already, I am about to post some in another thread. You are welcome to come over this Saturday and help with the install or just hang out and eat bbq and drink beer with us while we install it also
__________________
