Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.0L V6 Specific General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-06-2009, 06:49 PM   #1
Thedeer2
Thedeer2's Avatar
Vehicle: 2005 Ford Mustang V6
Default !!!!Need Help!!! Head Gasket 4.0L
Out of nowhere I had my coolant blow out of my reservoir. Took it to the dealer and they said the the headgasket is broke, or I could have a cracked block that is allowing exhaust gases to enter my cooling system and over pressurizing the system to the point that it blows off.
They gave me three options.
1. Bite the bullet up front and put in a new motor with a 3yr/100mi. warranty. Most Expensive Option $5100 installed
2. Used Motor with a chance of this reoccurring and no warranty. 2nd most expensive.
3. Tear the motor down to the heads and have it possibly be just the head gasket. But I run the risk of it being more than the gasket itself, and having the problem snowball into my worst nightmare. and become really $$$$$
I have seen a few other posts where people have had the same problem. The car never once overheated. and has about 60k miles.
For those that have had this happen was it only the head gasket? or did it also wreck the heads?
Anybody know what choice I should make? or have any advice?
Thanks alot
Thedeer2 is offline   Reply With Quote
Old 07-06-2009, 07:12 PM   #2
jtstakelin
2009 Ford Mustang
jtstakelin's Avatar
Vehicle: 2009 Ford Mustang V6 Deluxe
This is the first head gasket issue that I have heard of. Hope this isn't going to become a pattern. What kind of mods have you done?
__________________
2009 MUSTANG V6 Deluxe Brilliant Silver
MODS: Airaid CAI, Pypes Dual Exhaust, GT rear bumper, 20% Tint
jtstakelin is offline   Reply With Quote
Old 07-06-2009, 08:09 PM   #3
Thedeer2
Thedeer2's Avatar
The car is as stock as they come.
Old 07-06-2009, 09:25 PM   #4
THEBLACKSTANG
Vehicle: 2006 mustang v6, Pony package, leather, shaker 500
That sounds horrible, I would also get quotes from reputable local engine shops as they may be able to provide the same quality of service as the dealer but at a lower price.
__________________
2006 Black on Black v6 leather, pony package, shaker, S&B intake, ford racing single exhaust
THEBLACKSTANG is offline   Reply With Quote
Old 07-07-2009, 08:27 AM   #5
28HopUp
MF Administrator
1985 Ford Mustang
28HopUp's Avatar
Vehicle: Classic SSP S197
Send a message via AIM to 28HopUp
Did they perform a compression test to see which cylinder is affected? Although I haven't heard of a stock 4.0L blowing a head gasket, that could be the cause, and the repair wouldn't be as expensive as a new/used motor. In terms of "internet diagnostics", from what you've typed I doubt that it's a cracked block.
__________________
1985 SSP Mustang - California Highway Patrol Unit #E408395
We are the music makers, and we are the dreamers of dreams - Willie Wonka
28HopUp is offline   Reply With Quote
Old 07-07-2009, 09:10 AM   #6
Vehicle: 2006 Ford Mustang Pony Vert
I had the same thing happen last summer on my car - pre nitrous (CAI and tune, and quite a bit of track time). Only a head gasket replacement, no other damage to anything and I was around 80,000 miles at the time.
__________________
Xcharger #020, J&M LCA/UCA; 8.8/3.55 & LPW cover; Dual GT500 take offs. Black bullitts. Shaftmaster aluminum DS. PB: 13.60 @ 100+ juiced - Xcharger: 13.42 @ 101
JimC is offline   Reply With Quote
Old 07-17-2009, 05:40 PM   #7
Joshspony
2006 Ford Mustang
Joshspony's Avatar
Vehicle: 2006 Mustang Coupe PP
With no up coming symptoms it sounds kinda weird. Hopefully is it just a head gasket, I would recomend checking out that first. Two things will happen, it will either be the head gasket and you replace it, or it could be worse. If it is worse than you already have the motor partly torn down and easier to continue further.
As "theblackstang" said, check with a local engine shop. Most times you can get service the same or better quality from guys that work with engines everyday. And they probably won't be as pricey.
Good luck and let us know what you find out.
Joshspony is offline   Reply With Quote
Old 07-18-2009, 08:22 AM   #8
Thedeer2
Thedeer2's Avatar
Replaced the motor with Brand New and still have coolant spewing out the reservoir cap
Old 07-18-2009, 10:23 AM   #9
SixN2
Vehicle: 08 V6
Have you tried replacing the reservior cap?
SixN2 is offline   Reply With Quote
Old 07-18-2009, 01:30 PM   #10
157db
Got Troy'd
157db's Avatar
Vehicle: 2007 Pony Package
Quote:
$5100 later and it was just a bad coolant cap.
__________________
NON PUMKIN JACKER
Quote:
Originally Posted by Boozshey View Post
Oh yeah, I forgot Norm was God on here.
Give me a break!!!
Quote:
Originally Posted by Norm Peterson View Post
<rises to the bait>
. . . Definitely not God.
Norm
157db is offline   Reply With Quote
2005, 40, 40l, failure, ford, gasket, gaskets, gt, head, headgasket, mustang, replace, symptoms, v6
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
