Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.0L V6 Specific General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-26-2009, 08:16 PM   #1
obxdude018
obxdude018's Avatar
Vehicle: 2005 Ford Mustang
Default Underdrive pulley
What do people think about the underdrive pulley and is it worth the cost or if replacing this isn't a good way to go what else should I spend my money on, I have 4.10 gears and a lsd getting installed Tuesday, I have diablosport pred. tuner, CAI, and exhaust system, what would be another good upgrade for a reasonable cost.
obxdude018 is offline   Reply With Quote
Old 07-27-2009, 12:08 AM   #2
The Razor
The Razor's Avatar
Vehicle: 05 Screaming Yellow V6
I heard you can get between 2-5 hp. Seems like a bit of expense for so little added hp.
Then again, every little bit helps.
__________________
That which does not kill you makes you stronger.
The Razor is offline   Reply With Quote
Old 07-27-2009, 03:07 AM   #3
my first mustang
Vehicle: 2005 V6
You have an 05 so your driveshaft doesn't have lock-rings/snap-rings on the universal joints. I also had a vibration at 72-73 mph that just wouldn't go away. An aluminum driveshaft cured the problem and is much safer then stock. Stock shaft is 30 lbs. and aluminum is 17.5 lbs. Car just felt like it has more pep. No added HP but like gears lets you use your horsepower to better advantage. I think Shaftmasters gets about $450.00 now. Let him know your a member and he ships free. The 4.10s & T-Lok will make a VERY BIG difference too!
__________________
White 2005 V6 coupe w/automatic. FRPP M5230V6 dual exhaust. VMP cai w/VMP 93 mileage tune. Shaftmasters 4 in. aluminum driveshaft. 8.8 T-Lok w/3.55s. 17x8 in. black FRPP Bullitts w/Pirelli 235-55s. 14.65@93.58
my first mustang is offline   Reply With Quote
05, 2005, 40, 40l, 4l, cai, drive, forum, horsepower, mustang, pulley, pulleys, pullleys, underdrive, v6
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
