Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.0L V6 Specific General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-25-2009, 03:23 PM   #1
xxmax76
xxmax76's Avatar
Vehicle: 2007,ford Mustang V6 4.0
Default RPM LIMITER
Hi!
i need one info about my AUTO Trans Mustang;
I will disable the rpm limiter in neutral gear;dafault is 3.500/4.000RPM,i can use Diablo Predator tuner..i don't like this setting---
Thanks to all..
Bye!
__________________
2007 V6 Mustang
K&N Cold Air Itake
JBA short headers and True Dual Exhaust
Diablo Predator Tuned
Zex Nitrous(work in progress),
20'wheels
xxmax76 is offline   Reply With Quote
Old 08-26-2009, 12:20 AM   #2
tx_zstang
tx_zstang's Avatar
Vehicle: 2005 Mustang V6
Why? It's there to protect the motor. it can be increased, but leave it enabled.
__________________
Mike - 2005 V6 Automatic, 300+ RWHP; 12.79 1/4
Vortech supercharger (SOLD); 180*T-stat; PLX Wideband O2, VEI digital gauges, SOS pillar pod; JBA 9MM wires; Mac LT headers, high flow cats; 8.8 w/3.73s, LPW girdle, alum driveshaft, 3000rpm TC; Steeda UCA, panhard bar, brace; CHE lca's & reloc brackets; Steeda Sport springs, Tokico DSpecs.
.. "Sally" is getting "balls" ...forged V8 swap in progress
tx_zstang is offline   Reply With Quote
Old 08-26-2009, 11:20 AM   #3
157db
Got Troy'd
157db's Avatar
Vehicle: 2007 Pony Package
Get a higher stall torque converter before increasing the rev limiter...
Hardware to support the software....
__________________
NON PUMKIN JACKER
Quote:
Originally Posted by Boozshey View Post
Oh yeah, I forgot Norm was God on here.
Give me a break!!!
Quote:
Originally Posted by Norm Peterson View Post
<rises to the bait>
. . . Definitely not God.
Norm
157db is offline   Reply With Quote
Old 08-27-2009, 11:53 AM   #4
tx_zstang
tx_zstang's Avatar
Yeah that'll make you rev up more, but in drive.
In neutral, well, that's only for revving up for sound I would suppose.
__________________
Old 08-27-2009, 01:04 PM   #5
ODDYSEY
4.0L Section Moderator
2007 Ford Mustang
ODDYSEY's Avatar
unless he is doing some neutral slams.. which that would be not recommended either.
off-topic
Mike, was it you that made comment about my battery at the cruise? About it still being stock?
__________________
V6 of Fury! - X-Charger #101 - HI-PO Plus 2.8 | FRPP GTA's | FRPP 3.73 & T-Lok | FRPP springs | Tokico D-Specs | BMR Panhard | Razors - 18x9 | Nitto 555's | Auto Meter - Nexus gauges | Shaftmasters aluminum driveshaft | TCI ratchet shifter | Moroso tanks | UPR catch can | and more...
Click here to view the V6 of Fury!
ODDYSEY is offline   Reply With Quote
Old 08-27-2009, 01:30 PM   #6
tx_zstang
tx_zstang's Avatar
Quote:
off-topic
probably...sorry to jinx it
__________________
Old 08-27-2009, 03:48 PM   #7
xxmax76
xxmax76's Avatar
yes ;for sound !!
__________________
2007 V6 Mustang
K&N Cold Air Itake
20'wheels
Old 08-28-2009, 09:18 AM   #8
JCON
2005 Ford Mustang
Vehicle: 2005 Mustang V6 Convertible
Correct me if I'm wrong but, our stock drive shafts are weak and those rpm limiters (while in gear) keep our shafts from spinning faster than they can handle (or at least from spinning at the speed where those clips come out). In addition, if you remove it and rev too high won't you start floating your springs?
I pushed my limiter to 6350? But never go that high in gear and can't go that high in neutral.
__________________
DeMolet CAI w/ Tune
Single GT Manual Take Off
JCON is offline   Reply With Quote
Old 08-29-2009, 09:56 PM   #9
lundefinedl
Vehicle: 2005 Ford mustang
The driveshaft speed depends upon the gear. You'd have to be in like 5th gear at a high RPM to over-rev the driveshaft because it is after the tranmissions ratio's have been applied.
As far as the engine, the engine runs smooth at high RPM but isn't really tuned for it. Like you say, the valve train may be the weak link.
lundefinedl is offline   Reply With Quote
Old 08-29-2009, 11:12 PM   #10
THEBLACKSTANG
Vehicle: 2006 mustang v6, Pony package, leather, shaker 500
Ive heard people say that the stock rev limiter is set there in neutral because its not supposed to be good for you to rev your engine that high with no load on it. I don't actually know the mechanical reason behind it though.
__________________
2006 Black on Black v6 leather, pony package, shaker, S&B intake, ford racing single exhaust
THEBLACKSTANG is offline   Reply With Quote
05, 40, 50, diablo, disable, ford, increase, limit, limiter, mustang, perfect, predator, rev, rpm, setting, v6
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
