Quote:
Originally Posted by kda1967
Not sure how the back speakers come out of your 07. Check & see if you have speaker grills on the back deck. If so it is a lot less to take apart just make sure you have a ratcheting offset screwdriver. If no grills like my 08 you have to take out a lot of interior. Not too hard. If you do a search someone posted instructions & pictures. Not that hard took about 1.5 hours total including wiring up the sub.
05s are a little different than the 06-09 S197s.
06-09s require removal of most of the trim around the rear
window to be able to remove the parcel shelf to access the speakers.
If you do replace the rear speakers, do yourself a favor
and bottom mount the repacements for easier access next time...
