Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.0L V6 Specific General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-31-2009, 10:06 PM   #1
ericyo
ericyo's Avatar
Vehicle: 2005, Ford, Mustang
Send a message via AIM to ericyo Send a message via MSN to ericyo Send a message via Yahoo to ericyo
Default Car not starting help!
So the battery is fine. I had it checked. I'm not sure if its the alternator but I replaced it a year ago. Sorry im a bit of a newbie when it comes down to auto repair. But is there something else I'm missing? If I jump it, it works. But when I turn it off all it does is the click click click click noise and everything resets. Thanks for the help!
ericyo is offline   Reply With Quote
Old 10-31-2009, 10:16 PM   #2
Nuke
2007 Ford Mustang
My Garage
Nuke's Avatar
Vehicle: 2007 GT
Send a message via AIM to Nuke Send a message via Yahoo to Nuke
If the battery and alternator are fine, the battery voltage with the engine off should be above 12.5 volts. I'm not sure what the voltage should be at when cranking but I THINK it's 11.0 volts or higher. If you're car will crank and start with a jump, then it's one or the other. If your battery will accept a charge (overnight on a charger), then suspect the alternator... again.
__________________
Rick
07 GT Prem: Alloy, MT, 3.55's, Steeda CAI w/Brenspeed tunes, FRPP Stingers, 275/40/18 Goodyear Eagle F1 A/S on SVT Cobras (OE GT500's), 14" shorty, Wheelskin side scoops & qtr window louvers, A-H rear window louvers, SHR honeycomb blackout panel, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
06 V6: Legend Lime, Pony Package, 14" shorty, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
Nuke is online now   Reply With Quote
Old 11-01-2009, 10:11 AM   #3
JCON
2005 Ford Mustang
Vehicle: 2005 Mustang V6 Convertible
Sounds exactly like a dead battery. I would try the above methods.
__________________
DeMolet CAI w/ Tune
Single GT Manual Take Off
JCON is offline   Reply With Quote
Old 11-01-2009, 12:02 PM   #4
ericyo
ericyo's Avatar
Thanks guys. i'll check all that out. i'll update when i come up with the solution.
EDIT: one thing i forgot to mention... drivers side door was not working well. meaning when i would throw it up it wouldnt stop so it would hit the top and then refer about a quarter hight from the bottom up. but after this now it "semi" works. when i open it, it does that little automatic thing where it drops a bit but when i close the door it goes back up really slow. so dont know if that "might" have something to do with. At 1st i thought the damn cd thief aka shaker 500 was doing it. seeing as how it swallowed my cds.
Old 11-01-2009, 02:07 PM   #5
ericyo
ericyo's Avatar
Hey you guys think it might be the starter?
Old 11-01-2009, 05:24 PM   #6
Buckshot Barry
Quote:
My vote is a bad battery. The alternator must be working for the car to run after it is cranked. BTW, I'll assume the headlights are bright while the car is running when they are turned on.
__________________
Current Pony: '07 Vista Blue V6 PP, Dark Charcoal Cloth, T5 Man, Int SAP, ALB-TC, and Active Anti Theft. Built: 01/16/2007.
Past Ponies: '70 SportsRoof 302 C4 Auto, '88 GT 5.0 T5 Man
Buckshot Barry is offline   Reply With Quote
Old 11-01-2009, 05:34 PM   #7
1pony2go
2005 Ford Mustang
My Garage
1pony2go's Avatar
Vehicle: 2005,ford,mustang
Before you spend any bucks you might want to check if any of the connections are dirty,i.e.-starter,battery etc. I just had this same issue with my f250 and even after cleaning everything I could it still turned out to be a dead cell in the battery. good luck!
P.S. the battery tested good twice soooo?
1pony2go is offline   Reply With Quote
Old 11-01-2009, 08:23 PM   #8
JCON
2005 Ford Mustang
Shakers are known to kill batteries. I would say clean the battery terminals with a wire brush! My gf's 2000 had this issue and it turned out there was too much crap on the terminals on the battery. try cleaning and then if that doesn't work try wriggling them a little while someone else starts it, that will confirm whether or not you need to replace them
__________________
DeMolet CAI w/ Tune
ericyo, forums, mustang
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
