Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.0L V6 Specific General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-08-2009, 10:35 PM   #1
mustang green skin
mustang green skin's Avatar
Vehicle: 06 4.0L V6
Default Window problem
well my passanger auto down wasn't working so I did the re-calibration in the owner manual and now the window won't roll down all the way, it stays just over flush with the door. Also with the windows all up, they don't retract as far as they used to when the door is opened.
I've tried the recalibration method several times with no luck, any suggestions ?
__________________
Hurst shifter, GTA dual exhaust
mustang green skin is offline   Reply With Quote
Old 11-08-2009, 10:42 PM   #2
Torch_Vert
2005 Ford Mustang
Torch_Vert's Avatar
Vehicle: 2005 Ford Mustang
Will the window go all the way down manually? (i.e. without using the auto down feature)
__________________
2005 Mustang 4.0L V6 'vert
X-Charger S/N 004 (First X-Charged manual, First X-Charged 'vert)
Torch_Vert is offline   Reply With Quote
Old 11-08-2009, 10:53 PM   #3
mustang green skin
Vehicle: 06 4.0L V6
Quote:
its goes all the way up fine, but going down no, I tried to push the window itself down and it went with little effort but as soon as I tried using the window again it goes back to its usual shenanigans. So I tried pushing it down again and then recalibrating again but still no luck.
__________________
Old 11-09-2009, 11:12 AM   #4
157db
Got Troy'd
157db's Avatar
Vehicle: 2007 Pony Package
It has jumped the cogged track and is now out of
the recalibrations range of stop adjustments.
Its mechanical, not electrical.
__________________
NON PUMKIN JACKER
Quote:
Originally Posted by Boozshey View Post
Oh yeah, I forgot Norm was God on here.
Give me a break!!!
Quote:
Originally Posted by Norm Peterson View Post
<rises to the bait>
. . . Definitely not God.
Norm
157db is offline   Reply With Quote
Old 11-09-2009, 02:13 PM   #5
mustang green skin
Vehicle: 06 4.0L V6
so how do I fix that?
__________________
Old 11-09-2009, 02:15 PM   #6
Derf00
d-e-a-l-e-r-s-h-i-p
Derf00 is offline   Reply With Quote
Old 11-09-2009, 04:56 PM   #7
mustang green skin
Vehicle: 06 4.0L V6
is that the only way ? how complicated is it and how much do you think it would be ?
__________________
Old 11-09-2009, 08:04 PM   #8
mustang green skin
Vehicle: 06 4.0L V6
wait, I was just thinking. If it jumped the track then the window shouldn't function at all, right ? All that seems to be the problem is the stopping point I don't see how that means it jumped the track..
__________________
Old 11-09-2009, 10:17 PM   #9
chronos
chronos's Avatar
Vehicle: 09, Ford, Mustang
Maybe the stops are messed up? Easy way is to open the door up, (take off the door panel) and see what you can see. It's a heck of a lot cheaper than the dealer.
__________________
chronos is offline   Reply With Quote
Old 11-10-2009, 05:18 PM   #10
157db
Got Troy'd
157db's Avatar
Let me state that for you nit pickers.
It has jumped a cog on the belt.
One tooth out and the internal window stops
on the motor are now out of their adjustment/calibration
range.
Its a tooth or two out on the slotted 'belt'.
Or worse, its missing a slot divider.
d-e-a-l-e-r-s-h-i-p
__________________
NON PUMKIN JACKER
Give me a break!!!
<rises to the bait>
Norm
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
