I had my car dyno-tuned recently with XCAL2. But the dealer did not remove the 115mph governor. I also didnt get any instruction manual with the XCAL2, should I have??? Anyone know if this is something I can do myself without changing the custom tune? Or should I take it back and have them re-do the program?
End users (you and me) don't have the ability to remove the top speed limit. You'll have to ask your dealer/tuner to do it for you...
My XCal2 didn't even come in a box! It was just in a peanut filled box...instructions amounted to a small, 1 sheet/4 page set of instructions...basically worthless (and not really needed!!)
__________________
The Lovely Mrs. Hammy in her 'stang: 2005 Mineral Gray V6 Premium Vert - C&L CAI, SCT X-Cal2 with tunes by Alternative Auto, dual GT-take off mufflers, Magnaflow X-pipe
Thanks, I was trying to figure it out, but wasnt able to get anywhere. Getting Magnaflow duals installed tomorrow at the same dealer, will have him take care of it. Was hoping I could do it myself, oh well.
__________________
2005 V6 Convertible - Torch Red. Red Leather
Magnaflow Dual Exhaust, Eibach Sportline Springs.
XCAL2 Tuner, AEN Brute Force CAI, GT Rear bumper, GT front bumper/grill
Are you sure the XCAL can't remove the speed govenor? My pred had a option to remove it. And I doubt the pred would have a configurable option over the XCAL.
__________________
Best 1/4: 10.97@122.09, 1.56 60ft w/4.0 V6
Best 1/4: 11.23@117.11, 1.58 60ft w/5.4 V8 www.rygen.net/stang
You can remove the speed limiter... you need to have your dealer provide you with the .xtr files (tune export files). You then need to down load "extreme tune" from SCT. Use Extreme Tune to make changes to your tune (the .xtr files) and then upload it to the X-Cal2 so you can flash your car..
scrming---when I try to remove the speed limiter, it says I cannot do it because I need the file "removed.scv"
I have .XTR files from my dealer and from SCT directly. The same problem exists with each of them. Trying to remove the speed limiter triggers the error.
I've gotten too much practice loading tunes into the Xcal2
If you have the removed.scv file---would you be so kind as to share it???
__________________
I still don't understand how some Mustangs can have a top speed limiter and some do not. I've had my car up to 130MPH before and I felt I could have gone faster! I just didn't want to try and go faster than that because I have the cheepy stock tires on my car, don't want those blowing up! I swear, one of these days I'm going to do a video of my speedometer showing my top speed.
I just hope that when I do decide to get a XCAL2 or a Diablo tuner that it doesn't place the speed limiter on my car.
As far as factory settings? Wow, I'm suprised they aren't all the same. When you was car built?
As for SCT Tunes---the basic tune (at least for V6 autos) that comes from SCT to the dealers/vendors do include the stock limit of like 112 MPH. If you ask your dealer, it is likely that they'll raise it, or remove it. With current firmware, you cannot remove the speed limiter with the handheld unit. In my experience, you have to have the right file "extra file" (which I do not) to be able to remove the speed limit using their current Extreme Tune software. Who knows what the future holds...
As for Predator tunes---from what I've read, they can remove the speed limit from the tune via the handheld unit.
__________________
Ok, so I went back to the dealer yesterday, and had them install my Magnaflow duals, (by the way - they are AWESOME!!) and mentioned this to him. He actually showed me on his laptop connected to the tuner, where to change the top speed, but when we changed it, it does not take! He called SCT, and they told him that it should not be changed because of something with the gears at speeds of higher that 115mph. They told my dealer to have me data-log at 115mph (great, hope I dont get caught by the cops), and they would change it after seeing the data.
Thanks for the links SCRMING!
__________________
That sucks...you have to wait and risk a ticket. Dosent $400 bucks count for anything anymore. Dude, your ride sounds sweet, how about some more pics. Wait till your mufflers break in, you will love it even more. Mine are broken in and I love them.
__________________
