I really don't like the shifter in my v6 stang..Any way to fix this?
Shifting is not smooth at all, sometimes I can't get it into a gear (I have to use force) and so on.
Is there any way I can fix this without messing up the transmission (I talked to one mechanic and he said he wouldn't recommend getting a short shifter on a 06 v6 stang)
Also, a place where I could buy it from would help
thanks a lot
ps if I get the Hurst Shifter are there any short throws that look stock, I like the clean stock looking shifter, it completes the ensemble on the dashboard.
thanks a lot
RE: I really don't like the shifter in my v6 stang..Any way to fix this?
I believe there is a kit by Roush or pro-shifter that leaves the stock shifter in place. Hurst does sell black shifter *****, though you would still have the chrome stick. I'm curious why your mechanic said not to get a short-shifter for your car. It is a simple install and improves shifts dramtically.
Can you point as to where I could buy one from?
Also, how better is it really? I like smooth quick shifting, if you ever driven a g35 coupe or a bmw m3 those are amazing.
thanks
thanks
ORIGINAL: pat6674u
I think the Steeda shifter here is the simplest kit you'll find.
http://www.v6mustangstuff.com/05Drivetrain.htm
ORIGINAL: pat6674u
If I were doing this again, that's the route I would choose - it would be a half hour or 45 minute install, and you would always have the factory one to go back to if you wanted.
Here's the write-up on my install:
https://mustangforums.com/m_1787178/...tm.htm#1787178
Good Luck!
QWKYNUF
trashxtrash
09-20-2015 10:49 PM
