Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.0L V6 Specific General Discussion > 4.0L V6 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-12-2006, 01:16 PM   #1
DragonPL
Default Discussion on T-Locks
When upgrading the Gears do I need both parts like here:
http://v6mustangstuff.com/05Drivetrain.htm
Ring Gear and Pinion Gear (I'd go for 3.73 since I have Manual) for 7.5in for 2005 Mustang V6 AND the Ford Racing T-Lok Differential for 2005 Mustang V6 ????????? Or will getting both be a good mod??
is this an easy do your self thing???
Also is going to an 8.8 rear end only necessay when adding a blower or will it do anything just a stock???
EDIT: Changed subject line title to eventually make this a sticky - 28hopup
__________________
Now:
'09 GT Premium
- Manual w/3.55 gears
- C&L Racer CAI + Dyno Tuning
- Boomtubes Axlebacks
Had:
'06, V6 Premium
-Pony Package
-Manual Transmission
-MRT Axleback
-C&L CAI + 87 SCT Tune
DragonPL is offline   Reply With Quote
Old 09-12-2006, 02:32 PM   #2
mustangman02232
mustangman02232's Avatar
Vehicle: 04 F350 6.0
Send a message via AIM to mustangman02232 Send a message via Yahoo to mustangman02232
Default RE: T-Locks
the 7.5 is more then fine to handel the power
do NOT get a t-lok, they were designed for a 120 HP bronco 2, you cars put out almost twice as much RWHP
on a T-5 tranny, go with 4.10 gears, 3.73s are a waste even with a centri blower
http://www.drivetrainspecialists.com...-75/index.html
get a detorit true trac, which has no clutches to wear out unlike the crap-lok and a rear girdle and your car will be fine for over 350 HP
__________________
2004 Ford F350 6.0 PSD
MBRP 4" turbo back, no muffler/kitty, autometer boost/pyro/trans, SCT X-cal with innovative tunes, MISC appearance, fisher MM2,
not installed: arp head studs, cooling mods, 03 turbo, cfm "small mouth" elbow, ARP head studs, BPD EGR delete
SOLD:
2002 Mustang v6 vert
LTs, catted H, K&N FIPK, SCT X-3 with vmp tunes, misc appearance
RIP tripsevn7
4/1/77 - 7/27/08
mustangman02232 is offline   Reply With Quote
Old 09-12-2006, 03:02 PM   #3
DragonPL
Default RE: T-Locks
So you recomend 4.1 gears + TRUETRAC instead of t-lock.....?
__________________
Now:
'09 GT Premium
Had:
'06, V6 Premium
-Pony Package
-MRT Axleback
Old 09-12-2006, 06:07 PM   #4
scrming
Default RE: T-Locks
Quote:
ORIGINAL: mustangman02232
THAT IS COMPLETE AND UTTER BULLSH*T!!!! I have pounded on mine for over 30,000 miles! I launched HARD on a 125HP shot of N20 making almost 500 ft/lbs of TORQUE, with drag radials that did not spin! And before the 8 passes on the 125HP shot I had dozens of passes on the 100HP shot putting down over 400 ft/lbs! HELL i broke my MOTOR and the trac-lok is working at good as the day it was put in!!! Stop spreading this MISINFORMATION!!! Do you have some vested interest in Detroit Locker???
The fact is the only know person that has broke a Trac-Lok is powerhouse... and that was AFTER they had already broke the axles and replace those!!! And the reason they broke the trac-lok was because they were spaying 125HP shot of nitrous and then droping the clutch at 5000 RPM on slicks!!! I don't think anyone on this forum will be doing that anytime soon! The fact is the Trac-Lok will hold up to a LOT more abuse than 99.99% of the people in here will do... and if anyone does get that crazy they'll twist their axles FIRST!!!
__________________
scrming is offline   Reply With Quote
Old 09-12-2006, 07:04 PM   #5
rygenstormlocke
rygenstormlocke's Avatar
Send a message via AIM to rygenstormlocke Send a message via Yahoo to rygenstormlocke
Default RE: T-Locks
I havent broken my TLOK, have nearly 50 track runs on it. I was at 362rwtq (dynojet) on the juice, and at 347rwtq (mustang dyno, add 12% to match dynojet numbers) on it with no issues. Had it checked a few times, and will be checking it soon. Scrming never broke his, I think its a manual vs. auto. If you are a manual launch at 5k, sure, you can break one....but an auto, I doubt it.
Though I will be the first to put a stall on the tlock, but I am having a TA girdle put on as well to see how it holds up.
More to come on that.
__________________
Best 1/4: 10.97@122.09, 1.56 60ft w/4.0 V6
Best 1/4: 11.23@117.11, 1.58 60ft w/5.4 V8
www.rygen.net/stang
rygenstormlocke is offline   Reply With Quote
Old 09-12-2006, 07:09 PM   #6
Miami Mustang
Default RE: T-Locks
Quote:
ORIGINAL: scrming
Thanks for clearing that up scrming. And while we're still on the subject of t-loks: How much would be a fair charge for an install or is it something that can be done at home? Any how-to guides or write ups for it? I couldn't find one here.
__________________
Black 2006 Mustang V6 with Pony Package
http://www.cardomain.com/ride/2154302
Miami Mustang is offline   Reply With Quote
Old 09-12-2006, 07:27 PM   #7
scrming
Default RE: T-Locks
Quote:
ORIGINAL: Miami Mustang
Quote:
ORIGINAL: scrming
Not sure what a fair price is for an install.. I know it's not something I would want to do in my drive way... Most guys also do gears when they put in an LSD... I was on a very tight schedule and was in a hurry so I didn't shop around for parts, so I ended up buying all my parts from the shop that did the install... (which by the way recommended the trac-lok even though they could have easily sold me the more expensive true-track! This shop specialize in gears and clutches... they carry EVERYTHING! LOL). So over paying a bit for parts I got my gears and trac-lok installed and out the door for $900...
__________________
Old 09-12-2006, 07:51 PM   #8
Miami Mustang
Default RE: T-Locks
$900!!! [:@] I'm already planning to spend about $700 on suspension and I just want the t-lok too. I know it won' be nearly as much for what I want but still. Oh and I'm not paying to get the suspension done, I'll be doing that. I'm gonna try to do some research on the t-lok later tonight and I'll post if I find anything.
__________________
Old 09-12-2006, 08:38 PM   #9
HurricaneStang
Default RE: T-Locks
Oh look theres ANOTHER mustangman post on truetrac lol i just got done posting in another thread about him saying it in everyone lol. Im not sure but if i were you mustangman you might wanna get a different opinion on Ford T-lok cuz you got 2 people who actually race at the track with alot of power and they say it works good for them so...
__________________
2005 Mustang GT Coupe
Mineral Gray, Premium Trim
Automatic, Leather, Shaker 1000, IUP
HurricaneStang is offline   Reply With Quote
Old 09-12-2006, 10:19 PM   #10
8cd03gro
Default RE: T-Locks
you can get the gears, tloc, plus install for aroun 700. This is NOT something you want to do yourself unless you already know for a fact you can do it. It would be kind of pointless to not do gears with the t-loc unless you are goin f/i or something. while your rear end is open you might as well have them install the gears so i wouldnt just not get gears to save some cash, you will want some in the long run anyway.
__________________
Waiting and saving up money to go to a monster v8 daily driver of some sorts
8cd03gro is offline   Reply With Quote
2008, 4r3z4010ba, gt, gts, hood, installing, locks, mustang, mustangs, parts, price, tlocks, trufiber, twist, v8
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
