Aftermarket driveshaft
Old 09-16-2006, 10:53 PM
Nuke1
Nuke1's Avatar
Default Aftermarket driveshaft
I am a newbee so bar with me. Is there a definitive advantage, over the weight saving, in swapping for an aftermarket drive shaft like the on here :
http://powerhouse411.com/catalog/ind...products_id=84
More HP? More torque? Thanks
Nuke1 is offline
Old 09-16-2006, 11:23 PM
HurricaneStang
HurricaneStang's Avatar
Default RE: Aftermarket driveshaft
No not really...The upgraded driveshaft is really only needed if your driving at like 120mph+ or have alot of power under the hood. It wont bring added HP or TQ just is better then the stock driveshaft so you dont bust it driving your car hard.
HurricaneStang is offline
Old 09-16-2006, 11:26 PM
28HopUp
MF Administrator
28HopUp's Avatar
https://mustangforums.com/m_1286750/tm.htm
The above link is now a sticky in the 4.0L drivetrain section, and it explains exactly what could happen to the driveshaft on the early 2005's that did not have retaining clips on the u-joint caps.
Bill Jr.
28hopup
28HopUp is offline
Old 09-17-2006, 01:36 AM
8cd03gro
8cd03gro's Avatar
ORIGINAL: Nuke1
you won't get alot but you will get some, and the more mods you do, the more you will get from it because you will really gain a percentage. The saved weight doesn't help much in weight of the car prespective, but there is alot less rotating mass, so you will gain a few horses.
8cd03gro is offline
Old 09-17-2006, 03:08 AM
HurricaneStang
Oh really? I didnt think you gained any power from it but i didnt take into consideration how much it spins.
Old 09-17-2006, 03:30 AM
8cd03gro
8cd03gro's Avatar
you don't technically gain any hp, it just puts more of the crank horsepower to the wheels.
8cd03gro is offline
Old 09-17-2006, 05:53 AM
HurricaneStang
Ohh so it just shows higher numbers but its just more power getting to the wheels...Gotcha Chief
HurricaneStang
Is there any upgraded driveshafts you can buy thats cheaper then the $500 Power House?
Old 09-17-2006, 01:03 PM
05BlackPony
05BlackPony's Avatar
ORIGINAL: HurricaneStang
I do believe one sixer member here contacted a local driveline shop in his area for a new custom shaft.
I think it was about $100 cheaper, but it really all depends on if you can find a shop that can make you a dependable
piece for that good of a price.
05BlackPony is offline
Old 09-17-2006, 01:08 PM
randy78045
randy78045's Avatar
I got mine from Ford Performance....
randy78045 is offline
baddog671
07-26-2016 01:20 PM
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
Matt's 95 Stang
10-05-2015 07:16 AM
wraith777
09-28-2015 10:49 AM
09-24-2015 09:18 PM
Quick Reply: Aftermarket driveshaft
