If I were to find a wrecked S197 GT with a good 8.8" rear (drum-to-drum, so to speak), would the V6 driveshaft be a direct bolt-on? If not, what would be required to make it work (or would the GT driveshaft work). If a used GT rear could be utilized, that would be an inexpensive alternative to building up the 7.5" V6 pumpkin.
TIA,
Bill Jr.
28hopup
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________ 1985 SSP Mustang - California Highway Patrol Unit #E408395
We are the music makers, and we are the dreamers of dreams - Willie Wonka
I guess you mean disc to disc ...no drums on modern mustangs. The hp and tq limits on the 8.8 are much higher than on the 7.5 ..so it would be a good alternative to beefing up the 7.5. On the fitment issue i read somewhere that Shelby uses a plate to make the v6 driveshaft work with the GT rearend.
__________________
05 V6 AT,GT body kit,Saleen HID, 4.10's,C&L,JBA Shorties,Xcal2 89 tune
14.52@93.15 N/A & 13.52@103 on the 100 shot trackvid:
http://videos.streetfire.net/video/2005-Ford-Mustang-V-6-135--103_145613.htm
That is where I got mine, and having it drop shipped to PH. They did the swap on thier manual car, I will inquire on the specifics today.
and also it seems pretty cheap for an entire rear end. did u pay 500 or the original price, either one seems like a good buy. doesnt the ph driveshaft cost more than the rear end?
That is a great price, even with $160 shipping to the East coast. Plus the unit is a take-off with limited mileage. I know of one other possible source for GT rears. Either that or find a good used unit locally out of a 5-spd GT with a more desirable 3.55:1 8.8" LSD differential. Not sure if my local tuner could reset my XCAL2 to that ratio or not.
Bill Jr.
28hopup
if 100 HP is alot then i guess so, the 7.5 is capable of almost 400 RWHP with a true trac and TA girdle
__________________
2004 Ford F350 6.0 PSD
MBRP 4" turbo back, no muffler/kitty, autometer boost/pyro/trans, SCT X-cal with innovative tunes, MISC appearance, fisher MM2,
not installed: arp head studs, cooling mods, 03 turbo, cfm "small mouth" elbow, ARP head studs, BPD EGR delete
SOLD:
2002 Mustang v6 vert
LTs, catted H, K&N FIPK, SCT X-3 with vmp tunes, misc appearance
I researched this swap for my car and currently have a GT manual rear end with the 3.55 gears in shipping. The yoke or flange on the GTs is different from what the OEM V6 driveshaft requires, or what an after market V6 driveshaft will require. You need to replace the yoke with a P/N E9TZ-4851-A flange in order to mate the GT rear end to your V6 driveshaft. I verified this with a call to Shelby in Las Vegas where I talked to Ted about their CS6 vehicle. According to Ted, the CS6 rear ends Shelby is selling through Hillbank Motorsports have the Mustang GT flange replaced with the E9TZ-4851-A yoke (verified this P/N too). Ted said you can identify this flange because its face is flat, where the stock Mustang GT flange is a cupped shape. One of the guys who is building a CS6 using a Powerhouse V6 driveshaft reported he had no problem with the shaft installation using the Hillbank rear end with the E9TZ-4851-A yoke. Powerhouse also verified this P/N on the yoke.
