Are Euro-Spec DOHC heads compatible with our block?
Old 10-13-2006, 01:44 PM
DelStang86
DelStang86's Avatar
Default Are Euro-Spec DOHC heads compatible with our block?
any ideas, guys?
*wikipedia
2.9 Cosworth
A special DOHC version of the 2.9 was created by Cosworth Engineering in 1991. Although it shared the same block as the standard 2.9, power output was up to 195 PS (143 kW) and torque was boosted to 203 ft·lbf (275 N·m). This engine was used in the Ford Scorpio Cosworth 24V.
(disregard the hp/tq rating, considering this engine was using inferior PCM in 1991.)
DelStang86 is offline
Old 10-13-2006, 08:52 PM
DelStang86
DelStang86's Avatar
Default RE: Are Euro-Spec DOHC heads compatible with our block?
anything?
Old 10-13-2006, 09:27 PM
powerProdigy
powerProdigy's Avatar
huh?
powerProdigy is offline
Old 10-13-2006, 09:52 PM
DelStang86
DelStang86's Avatar
do you think we could swap the heads from the earlier cosworth v6's, because they're DOHC, and they're an earlier model of our current engine
Old 10-14-2006, 04:08 AM
MarioP3_XR4Ti
MarioP3_XR4Ti's Avatar
Probably not. The Cologne block 2.9 V6 is quite different from the late model SOHC 4.0 which is also quite different even from the previous 4.0's (which were also standard single cam pushrod motors) used in such as the Ranger and Aerostar and Exploder. The only thing that they share really is the bellhousing bolt pattern (and I am not sure if these 4.0's still do...) The Cosworth heads were intended for the Cologne based (originally single cam in block pushrod) 2.9 block only. I am a Merkur enthusiast and I plan on replacing one of my Scorpio 2.9's with a Euro-spec Cossie 2.9. I've also thought about dropping an '05 Mustang motor and manual into a Scorpio...
Of course, if you've the time and money you could probably get these heads onto a 4.0, but why? (I've seen people spend the money to modify Volvo DOHC 2.3 head to fit the 2.3 Ford SOHC motor. Pretty enough to look at, but again, why?) Bling?
MarioP3_XR4Ti is offline
Old 10-14-2006, 05:32 AM
Trill Gear Head
Trill Gear Head's Avatar
Just your stang blown and call it a day. If you want higher flowing heads get SSM heads.
Trill Gear Head is offline
Old 10-15-2006, 01:01 AM
DelStang86
DelStang86's Avatar
that's cool.. i was just wondering
FI is something i won't be able to afford for a while though.. paying for school and all
Old 10-15-2006, 01:53 AM
Trill Gear Head
ORIGINAL: DelStang86
if you couldn't afford FI, then why are you even thinkn about DOHC heads lol, that would be about the same price. The most thing your probably do is CAI and tuner. I say just get X-Cal and make your ride nice and shinny
Old 10-15-2006, 08:00 PM
DelStang86
DelStang86's Avatar
well... i'm taking out loans so i can afford to mod to some extent... i was thinking F.I. in a year or two
i was just wondering if it was possible... alot of curiosity really
i'm not so much about show either... i'm more interested in handling and power than looks (besides, it's a pretty bad-*** looking car as is)
Old 10-20-2006, 04:52 PM
chuckcsf
chuckcsf's Avatar
I'm refinancing my house with cash out and I might use some of that cash out for mods, maybe.... Well, if you got a house with equity and want to get cash out for mods, let me know. I work mortgages part time. I really want to get the items in my wish list before Christmas.
chuckcsf is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
Florida Regional Chapter
09-30-2015 08:04 PM
mustangheaven
09-29-2015 11:00 AM
junior04
09-28-2015 10:53 AM
Quick Reply: Are Euro-Spec DOHC heads compatible with our block?
