Left Side Mid Pipe Length
I'm finally getting around to ordering the left side (drivers side) mid pipe from Ford. I'm assuming it's the same length as the right side mid pipe that connects at the slip clamp though I'm not sure. Is this correct? If it is then I'll buy another slip clamp from Ford so both pipes will connect, or disconnect, at the same point. I'm trying to make this install as clean and as simple as possible for the shop that will fab the H-pipe and complete the install.
Thanks.
Thanks.
