Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.0L V6 Specific General Discussion > 4.0L V6 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-11-2007, 05:27 AM   #1
1bigdawg
Default wont start and is backfiring thru the intake
brought it to the dealer now the news is low compression in the 3 ,6 cylinders they want to take the top of the engine down to see if its the valves or somthing else in the top of the motor they are convinced the problem is in the top but then the service guy also said it may be a broke crankshaft isnt that in the bottom???? what would yall do from here
1bigdawg is offline   Reply With Quote
Old 07-11-2007, 06:41 AM   #2
GrayPony
Default RE: wont start and is backfiring thru the intake
What were the events leading up to the problem??
__________________
GrayPony is offline   Reply With Quote
Old 07-11-2007, 11:23 AM   #3
billybix76
billybix76's Avatar
sounds like a plain old blown engine. Only way the can happen is pushing it way past design limits...running at the rev limiter all day, or in rare cases parts (crank, timing chain, etc) failure...... and Ford will never admit that...
__________________
- Xcal3, DeMolet TI CAI
- Flowmaster AT - MGW shifter,
- CHE KBrace, SHaftmaster 3.5
- Hellwig rear sway, GT front sway
- 4 way Roush springs, J&M UCA/LCAs, T-lok, 3.73
- 17" bullits, 1/4 louvers, SS headers
billybix76 is offline   Reply With Quote
Old 07-11-2007, 12:20 PM   #4
1bigdawg
the events were that i parked it 1 nite woke the next morn went a few blocks and the eng lite came on and it started runnin lke s*** real ruff auto zone diagnosed it and claimed i needed plugs i changed them then it wouldnt start at all
Old 07-11-2007, 09:53 PM   #5
my first mustang
Vehicle: 2005 V6
In the old days this sounds like burned valves or blown head gasket,but what ever its bad news.Hope car is under warranty.
__________________
White 2005 V6 coupe w/automatic. FRPP M5230V6 dual exhaust. VMP cai w/VMP 93 mileage tune. Shaftmasters 4 in. aluminum driveshaft. 8.8 T-Lok w/3.55s. 17x8 in. black FRPP Bullitts w/Pirelli 235-55s. 14.65@93.58
my first mustang is offline   Reply With Quote
Old 08-24-2009, 07:43 PM   #6
stilbo
I know this is a bump to a two year old post but in the sake of informing members that might be freaking out over backfires through the intake on their 4.0, I'd like to add some resolve to this problem since there was never a follow-up posting.
I've torn down three 4.0's (2002 Explorer and two 2006 Mustangs) to find a broken valve. These engines had less than 70,000 miles on them but were out of warranty. A bent or stuck valve would have the same symptoms.
Why the broken valve stems? Not sure.... but the tensioner cassette may be part of the problem. I've heard and seen instances where the valve timing has actually jumped. Over revs with a weak tensioner assembly might be a contributing factor...
The labor to R&R the heads in the car adds up to a LOT of $. A LOT. Pulling the engine actually makes the job easier and the flat rate on labor is actually less to R&R the engine. Add the parts cost (a LOT) and the lingering fear that valve pieces might still be floating around.... you might consider the following.
Because of the costs and fears associated with repair of the engine in or out of the car, we have replaced all three engines with low mile salvage engines ($600.00, 58,000 miles average) with the total cost being slightly below repairing the original engines. We have pulled the valve covers, inspected the tensioner assemblies and have peace of mind...
The up side of replacement is that now you have a spare engine that can be stripped and rebuilt because salvage yards do not want the core. You can sell the engine or save it for parts.
Hope this helps any future "backfires through the intake" questions.....
stilbo
__________________
The Ford Farm
stilbo is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
