Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.0L V6 Specific General Discussion > 4.0L V6 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-18-2007, 01:55 PM   #11
157db
Got Troy'd
157db's Avatar
Vehicle: 2007 Pony Package
Default RE: Installing Fuel Filter, with pics!
Quote:
ORIGINAL: Fyrewalker
A few other points to mention.Some people mention pressing the fuel shut off button located on the drivers side footwell, I didn't feel the need, I cannot imagine it would have made a difference.
Thats not a FUEL SHUT-OFF SWITCH, ITS A FUEL SHUT-OFF RESET SWITCH.
Read your owners manual (again).
And oil on the buna o-rings, no thanks.
It will cause them to fail and gas will be
pumped out everywhere under pressure.
Workshop manual states to be sure and not
contaminate the seals with anything before
seating them. Looks like you will be needing
to do this over and with new o-rings to boot
or have the ever fear of the o-ring degrading
from contamination and blowing out.[:@]
Good effort, though. Just not the proper
procedure for fuel filter replacement.
__________________
NON PUMKIN JACKER
Quote:
Originally Posted by Boozshey View Post
Oh yeah, I forgot Norm was God on here.
Give me a break!!!
Quote:
Originally Posted by Norm Peterson View Post
<rises to the bait>
. . . Definitely not God.
Norm
157db is offline   Reply With Quote
Old 08-18-2007, 01:57 PM   #12
157db
Got Troy'd
157db's Avatar
A few other points to mention. I did not get a lot of fuel coming out from the fuel lines,
it was not under pressure, I would say about 4 ounces of fuel came out. Some people mention pressing the fuel shut off button located on the drivers side footwell, I didn't feel the need, I cannot imagine it would have made a difference. I agree with Derf00 do not get oil near the ends of the fuel filter, omit that step if you wish, I did it only near the base of the filter as I had read to do so in an old publication, of which I cannot find now. Total cost, below $20. Total time, under 30 minutes. Lastly, yes, that is my 3 year old "helper" in one of the pics, she increased the time by 10 minutes
The helper needs to be away from the lifted vehicle and gas and such.
Where is your brain, in your pants? Kids + workshop = trouble.
__________________
NON PUMKIN JACKER
Give me a break!!!
<rises to the bait>
Norm
Old 08-18-2007, 08:04 PM   #13
tilt
I just didthis today 23k miles. Have noticed a big difference as it is easier to start in first gear... dont have to give it so much gas. i thinks the filter was pretty plugged.
I did not bother to jack the car up, it was easy enough to just reach under the car and do the whole process minus oiling the adapters. I could not get the angle to use the screwdriver to undo the green tabs, but you can easily do it with your thumbnail.
tilt is offline   Reply With Quote
Old 08-18-2007, 09:56 PM   #14
nineinchnail1024
Vehicle: 2006 Mustang GT
Quote:
ORIGINAL: 157db
The switch can also be used to shut off the fuel. If you want to depressurize the fuel lines before changing the filter (i.e. the correct way) then you need to start the car, trip the shut-off switch, and let the car run until it dies. Then go about changing the filter, then reset the switch and restart the car. It may take a couple tries to restart; this is normal as there is no fuel in the lines.
__________________
Whipple Crew-10psi-Spec II-BMR LCAs-BMR sway bar delete-Spydershaft-M/T 26x11.5x17-Hurst-Prothane Mounts-PMP Line locks-Flows-Thump_rrr-Moroso separator-11.39@119mph
Daily Driver-2010 Prius-52.3mpg since new
Beater-1995 F150 XL-302 5spd
nineinchnail1024 is offline   Reply With Quote
Old 08-18-2007, 10:45 PM   #15
Fyrewalker
Quote:
ORIGINAL: 157db
Lighten up Frances....the car was safely on all four tires when the last pic was taken. Point taken on the
oil/contamination, I will not have issues or have to replace anything prematurely. As for where my brain was, I figured I didn't need it, I could just ask you since you already know everything.
Fyrewalker is offline   Reply With Quote
Old 09-05-2007, 03:38 PM   #16
GidyupGo
Vehicle: 2007 GT
Quote:
ORIGINAL: 157db
Best to go on and forget it. We get that from him quite often.[:'(]
__________________
2007 GT Coupe Premium Windveil Blue, Born on date...3/07
O ne
B ig
A ss
M istake
A merica
GidyupGo is offline   Reply With Quote
Old 09-05-2007, 04:25 PM   #17
05MustangSally
Vehicle: 2010 Mustang GT
Unfortunately, I didn't know about changing the fuel filter at 15K [:@]
I'm at 54K right now...I guess I know what I'm doing this weekend! [:-]
__________________
Bone Stock. For now.
05MustangSally is offline   Reply With Quote
Old 09-05-2007, 04:36 PM   #18
Fyrewalker
It really is a very easy job and it doesn't take long at all. I would omit the oil step, as it is contraindicated, you may be suprised at how much better your stang seems to run afterwards! Have fun.
Old 09-05-2007, 06:21 PM   #19
besam
where can i buy a quality fuel filter online?
__________________
'05 Auto Satin Silver V6 Auto
JLT II/MRT Exhaust/VMP 89 Oct. Tune/ and a few show mods
besam is offline   Reply With Quote
Old 09-05-2007, 07:17 PM   #20
05MustangSally
Kragen at www.partsamerica.com for like $15. Not sure of the quality, they only offer two different ones.
__________________
199, 2003, battery, cable, changing, disconnect, filter, ford, fuel, gt, mustang, mustang40fuelfilterchange, negative, replace, tino, upfiles771377166cb8262dc4e25994cb4663fb4cb24jpg, v6, why
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
