Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.0L V6 Specific General Discussion > 4.0L V6 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 04-28-2009, 11:45 AM   #51
luckydawg003
2007 Ford Mustang
luckydawg003's Avatar
Vehicle: 07 Ford Mustang GT
Well I just changed my fuel filter took 15 mins. Just remove the fuse 21, then try to start the car for like 5 secs. It shouldn't start. Then take out 3 bolts and 1 push pin on the black plastic cover. Then I put a trash bag around the old fuel filter since I knew it would spill fuel out. It did spill about 4-6 ounces. Take the 10mm bolt off the plastic piece holding the filter in to make it easier to remove. push the two green pieces in on the fuel line connector. and pull it away from the filter. Then slide the filter towards the engine side to get out of the plastic holder. Then replace with new filter reconnect lines, put fuse back in, then crank ignition like 4 times don't start...then start when the fuel line doesn't make the funny noise any more. check for leaks then reconnect the cover. Very easy to do. Didn't even have to jack the car up or disconnect the neg. battery. But ya wear gloves, I forgot to and now my hands smell like gas. Owell.
__________________
luckydawg003 is offline   Reply With Quote
Old 07-11-2009, 09:53 AM   #52
Sublime00
Vehicle: 2007, Ford, Mustang
Awesome walkthrough; the picture at the end really made it clear what to do with the shield. Did it flat on the street, and in retrospect, it's time to get a floor jack and stands...The green clips were a bit tricky (Tank-side was tougher than engine-side), but eventually popped them. Swapped, ran it for a few minutes to assure no leaks, re-bolted the shield, and off for a test drive; no issues.
Keep making this forum great, guys!
__________________
2006 4.0 V6
18" GT Take-Off Bullit wheels
GT-style grill and fogs
Full MAC C.A.I.
87 Tune
Sublime00 is offline   Reply With Quote
Old 07-31-2009, 06:02 PM   #53
tx_zstang
tx_zstang's Avatar
Vehicle: 2005 Mustang V6
Quote:
Originally Posted by tx_zstang View Post
So how do you repair one of the line ends that has its clip messed up?
Where can a replacement clip or hose end be obtained, and how would you put it on to withstand the pressure? (one of mine got f'd up during filter replacement)
Bump...
__________________
Mike - 2005 V6 Automatic, 300+ RWHP; 12.79 1/4
Vortech supercharger (SOLD); 180*T-stat; PLX Wideband O2, VEI digital gauges, SOS pillar pod; JBA 9MM wires; Mac LT headers, high flow cats; 8.8 w/3.73s, LPW girdle, alum driveshaft, 3000rpm TC; Steeda UCA, panhard bar, brace; CHE lca's & reloc brackets; Steeda Sport springs, Tokico DSpecs.
.. "Sally" is getting "balls" ...forged V8 swap in progress
tx_zstang is offline   Reply With Quote
Old 08-03-2009, 08:42 PM   #54
copternadle
Vehicle: 1981,auto,engine
I ordered the same borla exhaust too, and love the way it sounds it also looks very nice. I have people asking me all the time what kind of exhaust it is because it sounds so good. I got mine from borla parts here, borla 11761 and was pleased with the price a delivery time. You should also check craigslist sometimes you can find a used set.
copternadle is offline   Reply With Quote
Old 08-03-2009, 11:10 PM   #55
jimkaray
2005 Ford Mustang
jimkaray's Avatar
Vehicle: 2005 Ford Mustang Coupe
Quote:
Where can a replacement clip or hose end be obtained, and how would you put it on to withstand the pressure? (one of mine got f'd up during filter replacement)[/i]
tx_zstang they make replacement ends for most applications. That have about 12" of line along with the end the goes on the fuel filter. It comes with a hose barb that you use to join the old and new together. Heat the line up with some boiling water to expand it some and shove in the hose barb. I don't remember if clamps are required but it is extra peace of mind. I found them at Car Quest a few years ago when I broke one on my Taurus.
Fuel Line Nylon Repair Kit
__________________
4.0L, 5-Spd Stk, VMP MAF/CAI/93oct N2O Tune, T-Lok, Shorty Headers, FRPP Dual Exh kit, 18" Bullitts, CF Hood, Rr Louvers, SS Gen 1 Frt Cover, SHR Honeycomb Panel. ZEX N2O - 100 shot bests: 1/4mi ET 13.495 /MPH 103.95.
jimkaray is offline   Reply With Quote
Old 08-04-2009, 12:51 AM   #56
tx_zstang
tx_zstang's Avatar
TYVM!
__________________
Old 09-18-2009, 02:00 PM   #57
5T4NG
2007 Ford Mustang
5T4NG's Avatar
Vehicle: 07 Performance White
Send a message via AIM to 5T4NG
did this today with an 9$ filter from advanced. took a bath in gas but got it done
__________________
PERFORMANCE WHITE
MOD's--GT take-offs with custom H true dual exhaust, K&N drop in, 3M Metalized Tint, DIY 8" antenna.
5T4NG is offline   Reply With Quote
Old 09-20-2009, 10:15 AM   #58
robs
robs's Avatar
Vehicle: 06 GT Coupe
Phew... Thanks for the link... Some moron tried to pry out the little clip (like on every other car I've... er, the moron ever had)...
__________________
69 Mach I (Since 5/78) / 06 GT (Since 5/09) Boomtubes, sequential lights, Bama 91 Torque tune, Hurst billet shifter, J & M LCAs. Home brew lowering brackets next.
Life is better at WOT!!
robs is offline   Reply With Quote
Old 11-15-2009, 08:22 AM   #59
TPLSTNG
Vehicle: 2007 Ford Mustang Convertible
Thanks for the write-up. I changed mine yesterday at 31k. Maybe it will help improve my 16mpg average.
__________________
K & N air filter
Gt500 muffler
18" Dark Argent Bullitts
Sequential turn signals
Tinted Windows
Shaker 500 w/ Boston Acoustic speakers
TPLSTNG is offline   Reply With Quote
199, 2003, battery, cable, changing, disconnect, filter, ford, fuel, gt, mustang, mustang40fuelfilterchange, negative, replace, tino, upfiles771377166cb8262dc4e25994cb4663fb4cb24jpg, v6, why
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
