Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.0L V6 Specific General Discussion > 4.0L V6 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-18-2008, 07:10 PM   #1
Lethaldosage423
Lethaldosage423's Avatar
Vehicle: 05 Ford Mustang/06 Ford Mustang GT
Default HOW TO: Install C&L cold air intake with pics.
Well The day finally came!
My X cal3 Tuner and C&L cold air intake finally arrived. I had a few issues, Doug sent me the 93 tunes instead of the 91 tunes, all was sorted with an email, within 3 minutes i had the new tunes on my laptop, but my X cal didn't want to work. i connected with SCT remote assistance and had it fixed in a jiffy.
First step i took, was to install my new tune. I started off with the 91 Race tune.
So go ahead and plug in your SCT tuner into your ODB II port, located in the drivers side foot well:
Once plugged in, the screen should illuminate and it will make a noise.
Follow the steps on the screen, remember to have the radio off and all other accessories as it may drain your battery.
Now your tune is installed, its time to install the Intake (Dont start the car until both the tune, and the CAI are installed)
Make sure you have everything:
1. Connect the new metal air hose to the MAF housing. (Long pipe to short)
2. Pop the hood.
3. Remove the sensor from the old air hose:
4. Remove the MAF sensor. (Pull the red tab toward the car and push on the middle, and slide it out BE CAREFUL!)
5. Remove the old air hose from the throttle body Use an 8mm socket or a screwdriver and loosen the clip and it should pop right off:
6. Remove the stock air box. There is a 10 mm screw on the right side of it. dont lose the screw.
7. Remove the stock intake but dont trash it!
8. Remove the MAF Unit from the old intake. using the provided torx T-20 bit.
9 + 10: CAREFULLY remove the MAF Unit from the stock intake and slide it into your new MAF housing.
Using the screws provided, screw the MAF unit so its tight but not over tight. (Do Not Use Factory Screws From Stock, You May Damage The Thread)
11. Slide the new metal air hose onto the throttle body, you may need to loosen the clips.
make sure both the throttle body and the intake have an even amount of rubber sleeve on them, you dont want this popping off. Dont tighten it down yet.
12. Twist the MAF housing so the plug will line up without stretching the wire.
13. Loosen the clamp round the neck of your new air filter and place the black plastic shroud round it, slide the neck of the filter onto the end of your MAF housing, make sure the clip is in the middle and tighten this down lightly with a screwdriver.
14. Using the original screw from the old box, screw the black plastic shroud down so its rigid.
15. Now, tighten all the metal clamps down so they are firm, you need an 8mm socket for the filter and near the throttle body. And a 10mm socket used for the MAF housing.
16. Place the sensor with the green clip on your new intake. (I gave mine a clean with a dry rag first just to keep the dirt out.)
17. Clip the MAF sensor back onto your New intake and slide the red clip in away from the car.
18. Remove the plastic on your new filter
19. Stand back and enjoy!!!
*****SIDE NOTES*****
Keep all your stock things. if you need to get a smog test, you will have to throw the stock air box back on and reflash your car to stock.
Before closing the hood, make sure all tools are out from under the hood (Duh?)
Start her up and take her for a test drive, trust me you will burn some rubber.
Bring her back and check the new intake again incase a hose pops off or something.
Dont mind the Red X on my hand, its not a cut, i went to a concert last night and im 17 so i cant drink so they did that lol.
I would like to thank Doug from Bamachips.com For his great customer service.
and the tech dept. at SCT for there help.
My tunes i order were:
87 Perf.
91 Race
91 Torque.
-Chris Bevan
__________________
05 White V6 4.0
GT takeoff m/t single muffler--GT shocks and coils--15% tint--17x8 Bullitts--GT front end
Clear corners-- 14 inch Shorty Antenna--C&L / X-Cal 3 From BAMA. (91 Race Tune)
Roush Hood scoop C/S Rear bumper
06 Black Mustang GT A/T.
Maganaflow Axlebacks--18X9.5 Black Deep dish bullitts--Chrome taillight bezels
15% Tint
Lethaldosage423 is offline   Reply With Quote
Old 11-18-2008, 07:47 PM   #2
05MustangMarkIII
2005 Ford Mustang
Vehicle: 2005 4.0L Mustang
Nice write up!
+1
__________________
2005 4.0L V6 5-Speed
18" 7axis wheels w/ Pirelli 255
10" Racing Stripes w/ pin stripe
Dual Exhaust
Razzi side skirts, rear lip, GT bumper
Tinted fogs + Pony
Shorty Antenna
Raw Power Mustangs
www.myspace.com/rawpowermustangs
05MustangMarkIII is offline   Reply With Quote
Old 11-18-2008, 08:09 PM   #3
The Potato
2008 Ford Mustang
The Potato's Avatar
Vehicle: 2008 Mustang v6
Freaking awesome. Thank you, good sir.
__________________
2008 Mustang v6
- GT Rear Bumper, Roush 1/4 louvers
- FRPP Dual Exhaust
- C&L Intake w/ Bamachips tune
The Potato is offline   Reply With Quote
Old 11-18-2008, 08:21 PM   #4
project85
2006 Ford Mustang
project85's Avatar
Vehicle: 2006 Ford Mustang
He won't be back to respond for awhile... He's gotta be out testing it
__________________
Project85's STANG photo gallery... *CLICK*
project85 is offline   Reply With Quote
Old 11-18-2008, 08:26 PM   #5
AMoRT
Vehicle: 05
Awesome job man how do you like that combo?
__________________
^^^^FOR SALE: PM ME FOR DETAILS.
05 Sixxer, 55k miles
AMoRT is offline   Reply With Quote
Old 11-18-2008, 08:29 PM   #6
Lethaldosage423
Lol thanks for the complements.
3 words
IT IS AWESOME!!!!!!
i laid down some rubber (accientley) at the front and back of my neighborhood lol
i cant get over the difference and it even makes a cool noise when i rev it with the hood open.
I recommend this to ANYONE with an 05-09 Mustang lol
amazing!
__________________
05 White V6 4.0
15% Tint
Old 11-18-2008, 08:37 PM   #7
pthurm_28
pthurm_28's Avatar
Vehicle: 2005 satin silver
great thread will be getting one soon as long as I can get the $$$
__________________
pthurm_28 is offline   Reply With Quote
Old 11-18-2008, 09:34 PM   #8
bronxbomba63
bronxbomba63's Avatar
Nice write-up....hope to see it next month at the cruise!!
__________________
2005 Mineral Grey V6 Automatic
Show: 18" VSR gloss black rims, halo headlights, dual Flowmaster Super 40's, behind grille fogs, Cali Dream hood w/hood pins, 8" shorty antenna, blacked out trunk emblem and trunk panel
Go: Airaid CAI, dual Flowmaster Super 40's, 91 Race courtesy of Bamachips
bronxbomba63 is offline   Reply With Quote
Old 11-18-2008, 10:09 PM   #9
melo15fan15
melo15fan15's Avatar
Vehicle: 2007 Mustang 4.0 PP
Send a message via AIM to melo15fan15
Cant wait for my xcal to come in....its KILLING me
__________________
http://s3.photobucket.com/albums/y62...t=f779c922.pbr
CAI, ZEX 75 shot, Duals, DD Staggered Blk Bullits, 10" Blk Racing Stripes, 1/4 Window louvers, Shrty Ant, GT Front Bumper/grille, Complete Red Interior Dash, Chrome tailight trim, Red Painted Calipers, 4.0 Emblems, Blk C stripes, Painted GT Rockers, 3D Carbon hoodscoop, 3D carbon boyracer spoiler, Headlight Splitters, Custom pedals, blacked out tailights.
Tuned by BamaChips
melo15fan15 is offline   Reply With Quote
Old 11-19-2008, 09:27 AM   #10
ODDYSEY
4.0L Section Moderator
2007 Ford Mustang
ODDYSEY's Avatar
Quote:
3 words
IT IS AWESOME!!!!!!
amazing!
It is never on accident, it is your subconcius mind doing it because it's awesome!
Great write up!
__________________
V6 of Fury! - X-Charger #101 - HI-PO Plus 2.8 | FRPP GTA's | FRPP 3.73 & T-Lok | FRPP springs | Tokico D-Specs | BMR Panhard | Razors - 18x9 | Nitto 555's | Auto Meter - Nexus gauges | Shaftmasters aluminum driveshaft | TCI ratchet shifter | Moroso tanks | UPR catch can | and more...
Click here to view the V6 of Fury!
ODDYSEY is offline   Reply With Quote
40, air, boost, cai, cl, cold, ford, gt, installing, intake, kn, mustang, performance, roush, v6
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
