Tachometer pegged out
Hello to all, My wife came home from ER last with our son and was trying to tell me her problem she was having. She says the Tachometer was pegged out all the way to the right side, and still pegged out when engine is shut off and no she was'nt racing to get home . Any info would be helpful to us, I did disconnect the battery this morning and it did set back to normal to the left side. and has'nt pegged out since.Thanks Paul
I could explain it but I wont.
You would have to be a 'motorhead' to understand it.
And no it was not an electrical short.....
Did you get the unwanted underdash water dispenser option?
Maybe search the water leak TSBs?
yes there is a problem with rain/water being able to get in to the car through the firewall over on the passenger side. There is a fuse box over there where your feet would be. I would get that checked out.
The only fix is a new instrument cluster from the dealer. Mine was warrantied. All your odometer and other info is stored in the pcm so the cluster swap won't affect any of that.
Hope this helps.....
I was under the impression that the OD info was stored
in the cluster and not the PCM. Can you elaborate on
where you got your info about the OD info being stored
on the PCM and not the Clusters data storage?
Just curious
sure. as a way to test to make sure if it was the cluster. the tech grabbed a cluster out of another stang they had and plugged it in. all my information (odo, trip odo, mpg, etc) came right up......
also, i've heard of a couple of people who've bought clusters off of ebay and all their info was still displayed just fine.
