are you talking about the micro relays that go in the fuse box?
__________________
Progress Group, full adjustable front Aluminum Struts and rear suspension system, Adjustable LCA's & Panard Bar.Rear adjustable shocks Rotor Pros drilled and slotted (GT front) and rear Rotors - Yellow Calipers Cali Special rear bumper,CDC front Chin, MGW interior, Midwestern tower, mirror & radiator side covers, Street Scene Center Light Grill, and much more than they will let me post!
Most kits use the street scene harness that uses 1 relay. Which harness came with your kit. Can you go back to the seller and tell them you want the relays for the kit? (The relays should be included) Which switch does the kit use?
You might find them at parts store look for 30 amp relays , the one is a double contac , N/O and N/C it is the one you hook the Yellow wire into the high beam headlight wire OR the High Beam cut out relay ,, You could by pass this as another option then the Fog lights will work on both low and high beam ,, If you have the wiring diagram you can see where to make the jump ,,
+1
They are standard 30A Bosch Relays available at any good parts house.
There is only one package style and should fit the relay sockets you have.
Be sure and get the right relay. Some are only Normally Open and
dont give you the Normally Closed contact that your harness might need.
Some do.
__________________
NON PUMKIN JACKER
Quote:
Originally Posted by Boozshey
Oh yeah, I forgot Norm was God on here.
Give me a break!!!
Quote:
Originally Posted by Norm Peterson
<rises to the bait>
. . . Definitely not God.
Norm
