Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.0L V6 Specific General Discussion > 4.0L V6 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 05-12-2009, 06:27 PM   #1
Sublime00
Vehicle: 2007, Ford, Mustang
Default Hard starts in morning
06' V6
I've noticed in the morning that the car seems to bog when starting. I'll turn the key, the RPM's will dive below 0, but they hang there for a couple seconds and then the engine will fire. The rest of the day, it seems ok starting up, where a second after turning the key, it fires. Would this point to a possible battery issue, and if so, what's a good test (Other than the voltmeter to the posts; I'll prob get 12V if I can drive it all day) Any other suggestions?
Thanks
Sublime00 is offline   Reply With Quote
Old 05-13-2009, 09:14 PM   #2
up_yours_7
2005 Ford Mustang
up_yours_7's Avatar
Vehicle: 2005 Ford Mustang
It's not the battery cause I replaced mine with an optima red top and mine still does it I would lilt tobknow what causes it. I changed my plugs and fuel filter still does it
up_yours_7 is offline   Reply With Quote
Old 05-20-2009, 02:56 PM   #3
brentamis
Check you PCV valve. I has the same problem. Changed my PCV, plugs, fuel filter and cleaned my air filter and it went away. Not sure which was the culprit.
brentamis is offline   Reply With Quote
Old 05-20-2009, 05:22 PM   #4
157db
Got Troy'd
157db's Avatar
Vehicle: 2007 Pony Package
Morning Wood, maybe?
Seriously, its the difference between cold open loop
and warm closed loop starting...
__________________
NON PUMKIN JACKER
Quote:
Originally Posted by Boozshey View Post
Oh yeah, I forgot Norm was God on here.
Give me a break!!!
Quote:
Originally Posted by Norm Peterson View Post
<rises to the bait>
. . . Definitely not God.
Norm
157db is offline   Reply With Quote
Old 05-20-2009, 07:09 PM   #5
up_yours_7
2005 Ford Mustang
up_yours_7's Avatar
I have changed all but the pcv so it's got to be the pcv I will change that soon
Old 06-23-2009, 04:20 PM   #6
boarder_44
boarder_44's Avatar
Vehicle: 2007 Ford Mustang
I've got the same thing happening to my 07' V6 with 39k on it.
Did changing the PCV fix the problem?
boarder_44 is offline   Reply With Quote
Old 06-23-2009, 05:16 PM   #7
up_yours_7
2005 Ford Mustang
up_yours_7's Avatar
I will probably do it today if not to expensive I just did my fuel filter again
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
