Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.0L V6 Specific General Discussion > 4.0L V6 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-15-2009, 02:16 PM   #11
JCON
2005 Ford Mustang
Vehicle: 2005 Mustang V6 Convertible
Did you pull the codes yet? that will tell you exactly whats up, go to autozone or advanced auto parts
JCON is offline   Reply With Quote
Old 07-17-2009, 04:45 PM   #12
F0RD4LifE
codes? the only code i had was for bad tps which is replaced and the check engine light is gone.
As far as fuel filter and fuel injectors go, i replaced the fuel filter and used sea foam to clean the whole engine out. But the problem is still there, im about to clean the TB to see if that helps
PS. Does anyone have any idea why the idling gets MUCH worse when i turn on the AC?
F0RD4LifE is offline   Reply With Quote
Old 07-17-2009, 06:27 PM   #13
Joshspony
2006 Ford Mustang
Joshspony's Avatar
Vehicle: 2006 Mustang Coupe PP
The AC draws on the engine, so if you are having idle issues that would be why it gets worse when you turn it on.
Joshspony is offline   Reply With Quote
03, back, cobra, drop, explorer, express, fluctuating, idle, mustang, pick, problems, rmps, xcharger
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
