New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.0L V6 Specific General Discussion > 4.0L V6 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 06-18-2009, 09:28 PM   #1
hoju1015
Unhappy Temp gauge not moving from cold...
I think I have an issue with my temperature sensor. My temp gauge doesnt rise as my car warms up, its like its stuck on COLD. Im wondering if I have a faulty temp sensor or a faulty thermostat. Any ideas? Has anyone encountered this before? I know my car isnt overheating, its running fine, but I feel uneasy driving without knowing. I dont think its the electrical cluster as my fuel gauge, tach, and spedometer work just fine. Before I go buying random parts I wanted to check with my local experts.
Thanks for any ideas or help
hoju1015 is offline   Reply With Quote
Old 06-18-2009, 09:38 PM   #2
msafrit
Vehicle: 2008 Ford Mustang v6
Does the gauge rise at all? Has it just started doing this recently, if so, have you recently changed the antifreeze?
msafrit is offline   Reply With Quote
Old 06-18-2009, 09:59 PM   #3
nickel417
Vehicle: 2004 Ford Mustang GT
Send a message via AIM to nickel417
thermostat more than likely. Cheap fix too
__________________
2004 Mustang GT 5 speed-Flowmaster mufflers, o/r x-pipe, SCT X-CAL 3 Tuner(mail order tune), Roush Shifter, Roush CAI, Professional Products 75mm Throttle Body and plenum, Steeda Underdrive Pullies, H&R Super Sport Springs, MM C&C Plates, Tokico D-Spec Adjustable Shocks, UPR Tubular upper & lower control arms, Mach 1 Chin Spoiler, Mach 1 Grill Delete, Mach 1 Wheels
nickel417 is offline   Reply With Quote
Old 06-19-2009, 12:12 AM   #4
tx_zstang
tx_zstang's Avatar
Vehicle: 2005 Mustang V6
I would tend to disagree it's the t-stat. Temp would rise at least a little.
If you have datalogging capability, the best way to narrow the problem is to datalog the coolant temp. If it shows it changing to normal temps (around 190-200* or so), then your gauge is likely hosed. If the temp stays at 0, then it's likely the temp sensor or wiring or connector.
If the ECU thinks your car is still 'cold', it could affect how it runs.
__________________
Mike - 2005 V6 Automatic, 300+ RWHP; 12.79 1/4
Vortech supercharger (SOLD); 180*T-stat; PLX Wideband O2, VEI digital gauges, SOS pillar pod; JBA 9MM wires; Mac LT headers, high flow cats; 8.8 w/3.73s, LPW girdle, alum driveshaft, 3000rpm TC; Steeda UCA, panhard bar, brace; CHE lca's & reloc brackets; Steeda Sport springs, Tokico DSpecs.
.. "Sally" is getting "balls" ...forged V8 swap in progress
tx_zstang is offline   Reply With Quote
Old 06-19-2009, 06:36 AM   #5
Torch_Vert
2005 Ford Mustang
Torch_Vert's Avatar
Vehicle: 2005 Ford Mustang
There have also been issues with the stepper motors used to move the gauge needles failing. Another possibility.
__________________
2005 Mustang 4.0L V6 'vert
X-Charger S/N 004 (First X-Charged manual, First X-Charged 'vert)
Torch_Vert is offline   Reply With Quote
Old 06-19-2009, 09:34 AM   #6
Riptide
Riptide's Avatar
Vehicle: 2006 GT
You've let the car warm up with the cap off the radiator and made sure that the thermostat is opening up and it's flowing?
My old honda had a similar problem and it ended up being the thermostat. The needle did rise slightly off of cold though.
__________________
2006 GT, Manual
JLT2 w/93 Tune
FRPP 4.10, Steeda LCA
265whp/275wtq
Boomtube Crew Member
Riptide is offline   Reply With Quote
Old 06-19-2009, 10:02 AM   #7
157db
Got Troy'd
157db's Avatar
Vehicle: 2007 Pony Package
Quote:
Incorrect. A faulty stuck closed thermostat would cause overheating soon enough.
And a faulty stuck open thermostat would just make it take longer to warm up to
operating temps. I have run no thermostat in the summer before
and the temp guauge still performed flawlessly.
I just cant think of how a faulty thermostat could cause the
dashboard temperature guage to read cold all the time...
Can you extrapolate on this??
Quote:
Thats what I would suspect. Bad stepper motor in the cluster.
What year model is this problematic stang?
Hook up the ol MSD DashHawk and see if the can buss is reporting the
coolant temps to the cluster. That would find the problem.
Have you tried the troubleshooting charts for a faulty temp guauge
in the WorkShop Manual?
http://iihs.net/fsm/?dir=343&viewfil...nt Cluster.pdf
__________________
NON PUMKIN JACKER
Quote:
Originally Posted by Boozshey View Post
Oh yeah, I forgot Norm was God on here.
Give me a break!!!
Quote:
Originally Posted by Norm Peterson View Post
<rises to the bait>
. . . Definitely not God.
Norm
157db is offline   Reply With Quote
Old 06-21-2009, 10:48 PM   #8
chrisverneuil19
Vehicle: 2008, Mustange, V6 Coup
Its not a faulty thermostat. There are two temp sensors. One will show up in PIDS the other will not. One sensor is what the ecu uses to detect coolent temp. The other is for the gauge only. The ECU does not see this sensor. If the thermostat was broken ud see something. If anything
chrisverneuil19 is offline   Reply With Quote
Old 06-28-2009, 10:35 PM   #9
hoju1015
Thanks everyone for the advise. It doesnt seem to be the thermostat, and Im not really sure how i can check the ECU to evaluate which sensor it could be. Its really irritating though. I do have a diablo sport tuner, but I dont have the slightest clue how to use it to check anything... needless to say Im no car genius
To elaborate on the issue though, at first it would not register, Id turn the car off and then back on and it would rise to normal. the next day, same thing. Now it just doesnt rise at all. If it is one of the sensors, where would they be, and how would I go about checking them? Thanks everyone for your help on this
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
