Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.0L V6 Specific General Discussion > 4.0L V6 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-12-2009, 01:21 PM   #1
sirachknight
Vehicle: 2007 Ford Mustang
Send a message via AIM to sirachknight
Default 07 Mustang EGR valve
was wondering if anyone knew how to remove the egr valve on a 07 v6
sirachknight is offline   Reply With Quote
Old 09-12-2009, 02:22 PM   #2
157db
Got Troy'd
157db's Avatar
Vehicle: 2007 Pony Package
With a ratchet and socket?
Is it bad and if so how did you determine that
or is this a HP increase mod?
Here is the workshop manual online.
__________________
NON PUMKIN JACKER
Quote:
Originally Posted by Boozshey View Post
Oh yeah, I forgot Norm was God on here.
Give me a break!!!
Quote:
Originally Posted by Norm Peterson View Post
<rises to the bait>
. . . Definitely not God.
Norm
157db is offline   Reply With Quote
Old 09-13-2009, 01:33 AM   #3
sirachknight
well ya. is there a certain way to take the sensors off the top? the new egr doesnt come with them and requires you to swap them over.
Old 09-13-2009, 01:37 AM   #4
sirachknight
it started in fith and and worked its way to fourth gear. what was happening was id be going normal speed, and when i hit the gas the rpms would increase but the car wasnt going any faster. i cant slam the gas but when i hit it lightly it goes. i took it to the dealer and they determined (after 5 hours of troubleshooting) that the egr was going bad. i thought it might of been the maf or something else.
Old 09-17-2009, 03:56 PM   #5
partsbill
partsbill's Avatar
Exhaust Gas Recirculation (EGR) System Module
1. Disconnect the EGR system module electrical connector.
2. Disconnect the engine harness vacuum-to-EGR system module connector.
3. Disconnect the EGR system module tube-to-EGR system module fitting.
To install, tighten to 40 Nm (30 lb-ft).
4. NOTE: Upon installation, make sure to install the correct EGR system module mounting gasket. Even though varying gaskets may be very similar, orifice sizes may differ thus causing performance issues.
Remove the 2 bolts, the EGR system module and the gasket. Discard the gasket.
To install, tighten to 25 Nm (18 lb-ft).
5. NOTICE: Do not use metal scrapers, wire brushes, power abrasive disc or other abrasive means to clean the sealing surfaces. These tools cause scratches and gouges which make leak paths. Use a plastic scraping tool to remove all traces of the old gasket.
NOTE: The EGR system module sealing surfaces are soft metals.
6. To install, reverse the removal procedure.
Install a new gasket with the raised circle facing away from the EGR system module.
__________________
06 Blk GT 5sp/JLT II /XCALSCT2/Bama 93 RaceTune/FRPP Stingers/Hurst Shifter/GT500 Spoiler/Stage 3 window louvers/Steeda ultralite Springs/Bullitt Strut tower brace/07 Gt manifold cover/Shelby Lip/Seq t/lamps
partsbill is offline   Reply With Quote
Old 09-22-2009, 12:44 PM   #6
sirachknight
got all done but its still acting the same way it did
Old 09-22-2009, 12:51 PM   #7
Nuke
2007 Ford Mustang
My Garage
Nuke's Avatar
Vehicle: 2007 GT
Send a message via AIM to Nuke Send a message via Yahoo to Nuke
Didn't sound like an EGR valve issue to begin with. The dealer spent 5 hours troubleshooting and came up with THAT? I certainly hope you're still under warranty and don't have to pay his idiotness.
__________________
Rick
07 GT Prem: Alloy, MT, 3.55's, Steeda CAI w/Brenspeed tunes, FRPP Stingers, 275/40/18 Goodyear Eagle F1 A/S on SVT Cobras (OE GT500's), 14" shorty, Wheelskin side scoops & qtr window louvers, A-H rear window louvers, SHR honeycomb blackout panel, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
06 V6: Legend Lime, Pony Package, 14" shorty, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
Nuke is online now   Reply With Quote
Old 09-23-2009, 10:59 PM   #8
tx_zstang
tx_zstang's Avatar
Vehicle: 2005 Mustang V6
Possible tranny slipping? That certainly would not be the egr! If rpms increase, that rules out the engine not responding or not running.
__________________
Mike - 2005 V6 Automatic, 300+ RWHP; 12.79 1/4
Vortech supercharger (SOLD); 180*T-stat; PLX Wideband O2, VEI digital gauges, SOS pillar pod; JBA 9MM wires; Mac LT headers, high flow cats; 8.8 w/3.73s, LPW girdle, alum driveshaft, 3000rpm TC; Steeda UCA, panhard bar, brace; CHE lca's & reloc brackets; Steeda Sport springs, Tokico DSpecs.
.. "Sally" is getting "balls" ...forged V8 swap in progress
tx_zstang is offline   Reply With Quote
Old 09-24-2009, 10:22 PM   #9
Joshspony
2006 Ford Mustang
Joshspony's Avatar
Vehicle: 2006 Mustang Coupe PP
adaptive learning recal? it sounds like a bad case of autos downshifting at WOT
hopefully not slipping tranny - how is tranny fluid? level ok? smell or look burnt?
__________________
Mods:
Tint 35% on front 20% on 1/4s and rear.
Shorty billet antenna
Gt front bumper cover w/ fog light grill
CDC GT classic chin spoiler (black textured)
Gt rear bumper cover
Borla dual exhaust with X pipe & 4" tips
C&L CAI w/ Bama tunes 91 torque, 91 perf, 93 torque
Need more mod money!
Joshspony is offline   Reply With Quote
Old 10-04-2009, 04:13 AM   #10
sirachknight
tried this to see what n e one would think. put it in fourth and hit the gas. rpms went from 3300 to 4500 for about 4 or 5 seconds then slowly went down. if it is slipping would it be the clutch? this is my first manual car so i got some stuff to learn.
06, 2000, 2006, 2007, 40, delete, disconnect, egr, ford, module, mustang, remove, s197, system, v6, valve
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
