Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.0L V6 Specific General Discussion > 4.0L V6 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-13-2009, 12:47 AM   #11
mustang green skin
mustang green skin's Avatar
Vehicle: 06 4.0L V6
how would bending the hangers help, the brackets have the rubber inserts which hold the hangers and they flex alot so unless I bent them really far I don't see it helping any.
__________________
Hurst shifter, GTA dual exhaust
mustang green skin is offline   Reply With Quote
Old 09-13-2009, 10:24 AM   #12
JCON
2005 Ford Mustang
Vehicle: 2005 Mustang V6 Convertible
I did a single swap a few week ago and my clearance is perfect. equidistant on all sides. Loosen the clamp on the muffler, adjust it to where its not touch and tighten it. that is the best way to do it. nothing more is needed.... unless you bent a hanger, bracket, or pipe somewhere in the process earlier. try sliding the muffle back on the pipe as far as it will go.
__________________
DeMolet CAI w/ Tune
Single GT Manual Take Off
JCON is offline   Reply With Quote
Old 09-13-2009, 11:48 AM   #13
Nuke
2007 Ford Mustang
My Garage
Nuke's Avatar
Vehicle: 2007 GT
Send a message via AIM to Nuke Send a message via Yahoo to Nuke
DO NOT bend the hangers. Loosen the midpipe clamp near the tranny and at the axleback again and wiggle all the joints until you get the proper clearance. If it doesn't work, then it's possible the PREVIOUS muffler owner bent the hangers and THEN you may need to bend them. But make that your LAST resort.
__________________
Rick
07 GT Prem: Alloy, MT, 3.55's, Steeda CAI w/Brenspeed tunes, FRPP Stingers, 275/40/18 Goodyear Eagle F1 A/S on SVT Cobras (OE GT500's), 14" shorty, Wheelskin side scoops & qtr window louvers, A-H rear window louvers, SHR honeycomb blackout panel, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
06 V6: Legend Lime, Pony Package, 14" shorty, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
Nuke is online now   Reply With Quote
Old 09-13-2009, 01:04 PM   #14
JCON
2005 Ford Mustang
__________________
DeMolet CAI w/ Tune
Old 09-13-2009, 01:19 PM   #15
mustang green skin
Vehicle: 06 4.0L V6
well today I loosed up the muffler clamp and used a strap that was anchored down to keep the tip of the muffler perfetcly where I wanted it while I tightened the clamp back up and it did nothing for me. I tried it three times with no luck at all I even tried rocking the muffler up and down on the mid pipe but that didn't help either.
How do I check the hangers if they're bent ? cause before I put the muffler on they all seemed straight to me, nothing out of the ordinary.
__________________
Old 09-13-2009, 01:47 PM   #16
asci01
Vehicle: 05, Stang
Quote:
Originally Posted by mustang green skin View Post
I've still got the stock Y pipe, the h is my next project
Also, as I said before I've already tried the method of loosen clamp reposition then tighten with no luck. I've come to the conclusion that I think the pipe is slightly bent or the curve pipe of the muffler is a few degrees off from the stock v6 muffler, just enough to make the GTA collide with the bumper. So I don't think there is anything I can do but cut the bumper...
You shouldn't have to cut the bumper. Many people (including me) have done this swap on a V6 without the need to cut anymore the existing opening. Keep trying on bending the muffler hanger or slightly rotating the midpipe. Also, you could make a lower opening on the rubber part of the hanger closest to the bumper and use it for the muffler hanger.
asci01 is offline   Reply With Quote
Old 09-13-2009, 02:46 PM   #17
Nuke
2007 Ford Mustang
My Garage
Nuke's Avatar
Vehicle: 2007 GT
What about the other clamp at the midpipe-to-Y joint? We've been telling you all along that you need to loosen BOTH clamps and make adjustments at BOTH joints. Movement of the midpipe at the Y will result in altering the position of the muffler tip.
__________________
Rick
Old 09-13-2009, 07:55 PM   #18
mustang green skin
Vehicle: 06 4.0L V6
well it turns out the pipe alignment is fine, the previous owner must have bent the hangers cause that's what throwing it off.
__________________
Old 09-14-2009, 12:41 AM   #19
tx_zstang
tx_zstang's Avatar
Another thing you CAN do is to shim the rear hanger (put some spaces between the hanger and frame), to lower it a little bit. I have my passenger side rear hanger about 1/2" lower than the other side (cutout), and both clear properly and evenly.
The stock v6 tips are smaller diameter.
__________________
Mike - 2005 V6 Automatic, 300+ RWHP; 12.79 1/4
Vortech supercharger (SOLD); 180*T-stat; PLX Wideband O2, VEI digital gauges, SOS pillar pod; JBA 9MM wires; Mac LT headers, high flow cats; 8.8 w/3.73s, LPW girdle, alum driveshaft, 3000rpm TC; Steeda UCA, panhard bar, brace; CHE lca's & reloc brackets; Steeda Sport springs, Tokico DSpecs.
.. "Sally" is getting "balls" ...forged V8 swap in progress
tx_zstang is offline   Reply With Quote
Old 10-01-2009, 10:38 AM   #20
Ken04
Ken04's Avatar
Vehicle: 2006 V6 pony,2005 GT
parts out of the box rarely fit perfectly. This is where you need to become a little creative and use some mechanic'n skills. Bend the hangers around a little. Fit it back up, see if it makes it better or worse. Adjust accordingly. It aint rocket science, hot roddin is; 'adjust to fit'. I had to persuade mine with a hammer and a huge pair of channel locks.
__________________
her car; SMR #0951 06 V6 Pony, manual, mycolor, Shaker 1000, BMR lowering springs, adj track bar, center fog grill, 10" stripes, side window louvers, GT wheels. Pypes Violator cat back. Tri-bar grill emblem. GT500 splitter, rocker stripe delete, FIA/Shelby stripes, smoked front signals. FMC hood scoop.
My car, BMC #12073 black on black leather 05 GT. Manual, Shaker 1000, Shelby FIA stripes, NSP stainless axlebacks, Pro 5.0 shifter, Xenon window scoops.
Ken04 is offline   Reply With Quote
02, 2010, axle, backs, bumper, cut, ford, gt, gta, gtas, hitting, melting, muffler, mufflers, mustang, picture, tip, tips, v6
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
