Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.0L V6 Specific General Discussion > 4.0L V6 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-12-2009, 05:41 PM   #1
mustang green skin
mustang green skin's Avatar
Vehicle: 06 4.0L V6
Default V6 bumper/ GTA muffler problem
I just installed a used gta muffler from ebay on my v6 and the exhaust tip is pushing on the bumper. All it is an axle back install, just swapped the mufflers.
Will I have to worry about the bumper melting ?
and how do I shift the tip over so it isn't touching the bumper anymore ?
I know cutting the bumper is an option but I would really like to leave that to a last resort.
__________________
Hurst shifter, GTA dual exhaust
mustang green skin is offline   Reply With Quote
Old 09-12-2009, 05:44 PM   #2
157db
Got Troy'd
157db's Avatar
Vehicle: 2007 Pony Package
Pushing on the bumper where?
Pics?
The bumper will melt if it is touching it.
Loosen the first clamp on the intermediate pipe up by the tranny
and the GTA clamp.
Align the muffler tip and tighten the clamps.
Bend the hanger wires if so needed...
__________________
NON PUMKIN JACKER
Quote:
Originally Posted by Boozshey View Post
Oh yeah, I forgot Norm was God on here.
Give me a break!!!
Quote:
Originally Posted by Norm Peterson View Post
<rises to the bait>
. . . Definitely not God.
Norm
157db is offline   Reply With Quote
Old 09-12-2009, 06:17 PM   #3
mustang green skin
Vehicle: 06 4.0L V6
I loosed up the pipe clamp with no luck of moving it. Also the hanger brackets have a lot of give to them so idk what bending the hangers will do in terms of movement.
Also if you want some more specific pictures of something ask.
__________________
Old 09-12-2009, 06:26 PM   #4
mustang green skin
Vehicle: 06 4.0L V6
I don't think you can see it well enough in the picture but the tip is pushing on the bumper enough to bend it.
__________________
Old 09-12-2009, 08:25 PM   #5
jimkaray
2005 Ford Mustang
jimkaray's Avatar
Vehicle: 2005 Ford Mustang Coupe
It looks like if you get it aligned properly it may just clear the bumper. Loosen the clamp and have some one hold it in position while you tighten it. In the end you may find you'll have to bend the hangers at the muffler some to get it where you want it.
__________________
4.0L, 5-Spd Stk, VMP MAF/CAI/93oct N2O Tune, T-Lok, Shorty Headers, FRPP Dual Exh kit, 18" Bullitts, CF Hood, Rr Louvers, SS Gen 1 Frt Cover, SHR Honeycomb Panel. ZEX N2O - 100 shot bests: 1/4mi ET 13.495 /MPH 103.95.
jimkaray is offline   Reply With Quote
Old 09-12-2009, 08:55 PM   #6
asci01
Vehicle: 05, Stang
You may have to loosen the clamp after the H pipe to get additional room for the proper alignment. Just don't forget to tighten it after you're done.
asci01 is offline   Reply With Quote
Old 09-12-2009, 09:05 PM   #7
mustang green skin
Vehicle: 06 4.0L V6
Quote:
I've still got the stock Y pipe, the h is my next project
Also, as I said before I've already tried the method of loosen clamp reposition then tighten with no luck. I've come to the conclusion that I think the pipe is slightly bent or the curve pipe of the muffler is a few degrees off from the stock v6 muffler, just enough to make the GTA collide with the bumper. So I don't think there is anything I can do but cut the bumper...
__________________
Old 09-12-2009, 09:45 PM   #8
Vehicle: 2006 Ford Mustang Pony Vert
Are you sure that you have the hangers in the correct position? When we put my GT take offs on, at first they weren't lined up and found that the hangers weren't mounted in the brackets properly.
__________________
Xcharger #020, J&M LCA/UCA; 8.8/3.55 & LPW cover; Dual GT500 take offs. Black bullitts. Shaftmaster aluminum DS. PB: 13.60 @ 100+ juiced - Xcharger: 13.42 @ 101
JimC is offline   Reply With Quote
Old 09-12-2009, 11:58 PM   #9
mustang green skin
Vehicle: 06 4.0L V6
Quote:
How can they not be in the right position ? I only saw one hole for each screw.
__________________
Old 09-13-2009, 12:22 AM   #10
cobrabobby
Vehicle: 2006 Mustang V6
take a scrap piece of galvanized or black iron pipe and
slip over the welded brackets withe the long rod on each
end and bend them up a bit which will place the muffler
down in the bumper slot far enough for clearance. remount
to the rubber hanger and align and tighten. You'll have to
play with it a couple time to get them even. Easy to do.
Tighten the clamp to the midpipe end and you are good to
go. make sure the midpipe is not hitting bodyparts or the
rear or you'll here rattling.
__________________
cobrabobby
cobrabobby is offline   Reply With Quote
02, 2010, axle, backs, bumper, cut, ford, gt, gta, gtas, hitting, melting, muffler, mufflers, mustang, picture, tip, tips, v6
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
