Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.0L V6 Specific General Discussion > 4.0L V6 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-06-2009, 02:29 AM   #11
killdar
killdar's Avatar
Vehicle: 05 v6
Send a message via AIM to killdar
I like the way my h sounds w/ LT's. Its fi also, flowmaster mufflers, and highflowcats(magnaflow). will have to get a wot driveby clip sometime
__________________
05 v6 X-charged, ssw longtubes, magnaflow hiflo cats, h pipe, flowmaster AT axelbacks, 4in alum driveshaft, 8.8 rear w/ tlok and 3.73's, Roush qtr louvers and spoiler, gt facia and grill, staggered black saleen 5spokes w/ nitto 555's
killdar is offline   Reply With Quote
Old 10-06-2009, 08:53 AM   #12
Norm Peterson
2008 Ford Mustang
Norm Peterson's Avatar
Vehicle: 2008 GT Premium
Quote:
Originally Posted by tx_zstang View Post
But FWIW, it did seem an x-pipe provided a little more top-end power compared to no crossover at all. But this is all with a blower, too.
At higher rpm and certainly at higher power levels, that does not surprise me even with the sixxer. Of the three arrangements mentioned, an "X" is the best at sharing the flows between banks through both mufflers, which results in slightly less peak backpressure due to the left and right banks not peaking at precisely the same times. IOW, exhaust flow is not a steady thing, and the side that's instantaneously flowing less will help out the side that's flowing more. An "H" is less efficient at doing this, but still better than no cross-connection at all.
OP - you could run an X or an H either for a little more power under some conditions or to affect the sound. On the V8 side, an H definitely gives a more rumbly sound and an X is clearly a bit snarly (and either will generally run slightly quieter than straight duals at idle and low rpms with any given pair of mufflers). I don't think there's anywhere near this sort of difference between an X and an H with a 6, no matter whether it's an inline-6 or V6. So you might as well go with the one that's easier to install (or more readily available).
Norm
__________________
08 GT Premium Black/Light Graphite, stick, un-FStock
weenie-EP 626/V6/stick, Prepared just enough, sometimes
Norm Peterson is offline   Reply With Quote
Old 10-06-2009, 08:22 PM   #13
V6Vin
2007 Ford Mustang
V6Vin's Avatar
Vehicle: 2007 Ford Mustang
Thanks Norm, Readily available, Hmmm, what I have now is factory pipes and an axleback boomtube on the passenger side. Laying in my floor is the boomtube off the drivers side of a GT. I think all I need is to have the pipe bender cut out the Y and run pipe to the axleback on the drivers side.
I'm just debating the X, H thing or more then likely lack of either. decisions, decisions.
Vince
__________________
V6Vin is offline   Reply With Quote
Old 10-07-2009, 07:55 PM   #14
5T4NG
2007 Ford Mustang
5T4NG's Avatar
Vehicle: 07 Performance White
Send a message via AIM to 5T4NG
either way you go its better than that Y, thats for sure. get lots of quotes too from different shops, u wont belive the prices they'll throw at you.
__________________
PERFORMANCE WHITE
MOD's--GT take-offs with custom H true dual exhaust, K&N drop in, 3M Metalized Tint, DIY 8" antenna.
5T4NG is offline   Reply With Quote
Old 10-07-2009, 10:26 PM   #15
Paulejr13
Paulejr13's Avatar
Vehicle: 2007 Mustang Vert
im running no crossover on a 4.0, and it sounds good
__________________
Paulejr13 is offline   Reply With Quote
Old 10-07-2009, 10:31 PM   #16
V6Vin
2007 Ford Mustang
V6Vin's Avatar
Outstanding, Paul. Did the lack of crosspiece lower the sound at below 2500rpm?
What muffler are you using?
__________________
Old 10-07-2009, 10:45 PM   #17
Paulejr13
Paulejr13's Avatar
Ive got Gt Takeoff mufflers from a manual.
my car sound much bettter and louder than others ive heard with gt takeoffs. BUT, i will say the idle after warm up does drop low, and isnt too loud, but under load and driving it open up beautifuly
__________________
Old 10-07-2009, 10:46 PM   #18
Paulejr13
Paulejr13's Avatar
i think the somewhat quiet idle is dueto a mild muffler and stock header manifolds.
__________________
Old 10-08-2009, 07:22 AM   #19
V6Vin
2007 Ford Mustang
V6Vin's Avatar
When you have the crossover it seems like the exhaust notes run together being in one pipe, what I'm looking for is note separation from one side to the other. It should be very distinctive with the Boomtubes I have. I will try to get it on tomorrow.
I have a template, I just have to cut the bumper cover out for it.
Edit: I cut out the bumper cover and have the second Boomtube in place. Tomorrow it gets a pipe to it.
__________________
Old 10-09-2009, 03:44 PM   #20
V6Vin
2007 Ford Mustang
V6Vin's Avatar
Well, It's done. I got the Y pipe removed, put in a short connector for the passenger side pipe, and a new mid pipe back and over the axle. All done at a local shop for $92.
Sounds great. Eliminated almost all drone at 65-75. Lower tone at idle and up to 2500 then it really speaks up.
I'll try to do a vid in a few days if I can borrow a camera.
__________________
crossover, exhaust, pipe
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
