Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.0L V6 Specific General Discussion > 4.0L V6 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-05-2009, 05:26 PM   #1
V6Vin
2007 Ford Mustang
V6Vin's Avatar
Vehicle: 2007 Ford Mustang
Default Why use X or H crossover ?
I've ran duals on a lot of my old cars and until now never heard of X or H pipes.
Why even use these? Why not just run "real" dual pipes? you know, one on each side.
Is there some reason for making the pipes into one at the middle then back into two?
I do understand the sound difference in the X and the H, not my issue.
Sorry, but I have searched threads for 2 hours and found no mention of this.
Thanks, Vince
__________________
V6Vin is offline   Reply With Quote
Old 10-05-2009, 05:36 PM   #2
Shadow7874
2007 Ford Mustang
Vehicle: 2007 Ford Mustang GT
i think it has something to do with equalizing the pressure of the gas. I recall reading something about it but im unsure exactly.
__________________
07 Redfire GT Manual
DIY Shorty antenna, SHR Honeycomb Blackout Panel, wheelskins Louvers, GT/CS Rear Bumper, window tint, tinted turn signals
Awaiting install: BBK Chrome Shorties
Next in line: boomtubes?
Shadow7874 is offline   Reply With Quote
Old 10-05-2009, 06:12 PM   #3
onederful100
onederful100's Avatar
Vehicle: 2007 GT 1992 LX 5.0
let the Professor Wizard explain it:
http://mustangforums.com/forum/2005-...explained.html
__________________
Whipple Crew Member
2-Stang Crew Member
my car
onederful100 is offline   Reply With Quote
Old 10-05-2009, 06:18 PM   #4
ODDYSEY
4.0L Section Moderator
2007 Ford Mustang
ODDYSEY's Avatar
Read this article posted on MF.
It will explain alot. Keep in mind that is directed towards a V8 engine. Our V6's are slightly different. Over the years we have done alot of trial and error, and at one time we can up with the X pipe and H pipe have little effect over backpressure on the V6, there is a mild sound difference.
Ford developed a dual exhaust package for the V6 and it came with an x-pipe so that seemed to be the choice for alot of us.
__________________
V6 of Fury! - X-Charger #101 - HI-PO Plus 2.8 | FRPP GTA's | FRPP 3.73 & T-Lok | FRPP springs | Tokico D-Specs | BMR Panhard | Razors - 18x9 | Nitto 555's | Auto Meter - Nexus gauges | Shaftmasters aluminum driveshaft | TCI ratchet shifter | Moroso tanks | UPR catch can | and more...
Click here to view the V6 of Fury!
ODDYSEY is offline   Reply With Quote
Old 10-05-2009, 06:18 PM   #5
ODDYSEY
2007 Ford Mustang
ODDYSEY's Avatar
onderful you beat me to it! I typed out too much stuff :P
__________________
Old 10-05-2009, 06:21 PM   #6
onederful100
Quote:
i got you on the keyboard holeshot. lol.
__________________
Whipple Crew Member
2-Stang Crew Member
my car
Old 10-05-2009, 06:34 PM   #7
V6Vin
2007 Ford Mustang
V6Vin's Avatar
Thanks guys ! I think I got what I needed to know.
The following posted by professorwizard:
Some of you ask about a Cross Over on a V6.
In the case of the V6, with their 'Even Firing Sequence'. Having a crossover or not, is very dependent on the size of the exhaust and distance from the engine of the pipes placement. A cross over is not required if the exhaust is 'tuned' to the engine. Tuned systems are nearly always without a crossover pipe because the length and diameter of the exhaust is specifically designed to work with your engine at a specified RPM Range to avoid reversion and scavenging.
On a V6 there is no need for a crossover due to the even firing engine. However, it has been proven that in some instances, a crossover pipe will decrease backpressure and allow for a higher flow. If the crossover pipe is too close to the engine, it allows the pulse timing of the opposing cylinders exhaust cycles, to crash into each other – that is to say, the pressure from a right cylinder will still be present in the left pipe when the left cylinder opens to vent. Too far a placement can create a 'Pulse Vacuum', causing diminished pressure on the venting opposing cylinder, causing decrease in torque (Called Scavenging). .
Proper design and placement of the cross over will allow a balance of pressures across the system and therein increase torque, especially at lower RPM.
Also, it has been shown that having a cross over pipe mellows out the raspy 'ricer' sound that occurs above 3000rpm. So some people install them just for their 'sound' value.
So, the bottom line is, you probably should have a cross over pipe on a V6 exhaust, even though it is not needed. There is minor performance gain and sound gain as well.
__________________
Old 10-05-2009, 09:03 PM   #8
JCON
2005 Ford Mustang
Vehicle: 2005 Mustang V6 Convertible
I have some questions:
where do I find a tuned exhaust and what exactly is it other than an exhaust tuned for your engine?
where should the cross over be placed?
should I just run a Mac Prochamber on my V6?
__________________
DeMolet CAI w/ Tune
Single GT Manual Take Off
JCON is offline   Reply With Quote
Old 10-05-2009, 11:15 PM   #9
ODDYSEY
2007 Ford Mustang
ODDYSEY's Avatar
Easiest thing is to buy a kit, such as the FRPP kit, or the Pypes kit, that is tuned for the car and is basically just plug and play.
__________________
Old 10-06-2009, 12:24 AM   #10
tx_zstang
tx_zstang's Avatar
Well, LTs, high-flow cats, an X pipe, and GT takeoff mufflers sound like crap (ask ODDYSEY!). It was even worse with straight-pipes (muffler deletes).
But FWIW, it did seem an x-pipe provided a little more top-end power compared to no crossover at all. But this is all with a blower, too.
__________________
Mike - 2005 V6 Automatic, 300+ RWHP; 12.79 1/4
Vortech supercharger (SOLD); 180*T-stat; PLX Wideband O2, VEI digital gauges, SOS pillar pod; JBA 9MM wires; Mac LT headers, high flow cats; 8.8 w/3.73s, LPW girdle, alum driveshaft, 3000rpm TC; Steeda UCA, panhard bar, brace; CHE lca's & reloc brackets; Steeda Sport springs, Tokico DSpecs.
.. "Sally" is getting "balls" ...forged V8 swap in progress
tx_zstang is offline   Reply With Quote
crossover, exhaust, pipe
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
