Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.0L V6 Specific General Discussion > 4.0L V6 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-09-2009, 09:15 PM   #1
Mitch_
Vehicle: 2005, Ford, Mustang
Default Supercharger or turbo?
I have a V6 mustang and i have been looking into ways to give it that extra kick I'd like. So i started looking at turbos and superchargers. I've talked about it with a few friends and some pull towards super charger and the others pull for turbo being that its a V6.
So if anyone can lend me a hand here in deciding which way to get more power even if it's not the supercharger or turbo.
Mitch_ is offline   Reply With Quote
Old 10-09-2009, 10:14 PM   #2
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Vehicle: 2006 Ford Mustang GT
moved to the right tech section...this area is for introductions! welcome to the forum!
__________________
2006 Mustang GT with Cervinis Kit
Whipple Crew member
H.O. S/C 465 RWHP and 440RWTQ
First online article about my car! check it out!
http://www.examiner.com/examiner/x-8811-Detroit-Sports-Car-Examiner~y2009m5d30-Jason-McGuires-2006-Mustang-GT
http://www.cardomain.com/ride/3342086
www.mocsem.com
mygt500 is offline   Reply With Quote
Old 10-09-2009, 11:35 PM   #3
Torch_Vert
2005 Ford Mustang
Torch_Vert's Avatar
Vehicle: 2005 Ford Mustang
If the goal is simply "more power" either will work.
My personal preference is supercharging, especially the positive diplacement type, but in the end, they both get the job done.
__________________
2005 Mustang 4.0L V6 'vert
X-Charger S/N 004 (First X-Charged manual, First X-Charged 'vert)
Torch_Vert is offline   Reply With Quote
Old 10-10-2009, 08:11 AM   #4
conor1148
a supercharger could be cheaper, easier to install and maintain. but i think a good turbo would cost a little more, but be a little more tricky to maintain.
conor1148 is offline   Reply With Quote
Old 10-10-2009, 04:42 PM   #5
tx_zstang
tx_zstang's Avatar
Vehicle: 2005 Mustang V6
Differences come into the decision regarding mainly installation and initial cost. Maintenance should me minimal.
But mainly, how and where you'd use the extra power and why are important as well. If you want to for mostly drag racing, then turbo is better.
Supercharger setups are generally lower in cost to obtain and easier to install, and installation can be done by most moderately-capable weekend mechanics.
Another option is the x-charger. It's very popular with the v6 crowd as it is easiest to install.
Whatever you do, make sure your car is set up to handle the power, including a good custom tune for the blower.
It will put a BIG smile on your face
__________________
Mike - 2005 V6 Automatic, 300+ RWHP; 12.79 1/4
Vortech supercharger (SOLD); 180*T-stat; PLX Wideband O2, VEI digital gauges, SOS pillar pod; JBA 9MM wires; Mac LT headers, high flow cats; 8.8 w/3.73s, LPW girdle, alum driveshaft, 3000rpm TC; Steeda UCA, panhard bar, brace; CHE lca's & reloc brackets; Steeda Sport springs, Tokico DSpecs.
.. "Sally" is getting "balls" ...forged V8 swap in progress
tx_zstang is offline   Reply With Quote
Old 10-16-2009, 06:14 PM   #6
X3xMONGOOSEx3X
2006 Ford Mustang
X3xMONGOOSEx3X's Avatar
Vehicle: 2006, Ford, Mustang 4.0L v6
think compound boost IDK if you can use it with a v6 but it rocks my dads 5.0 v8.
http://www.hellionpowersystems.com/i...boost-resource
__________________
X3xMONGOOSEx3X is online now   Reply With Quote
Old 10-16-2009, 06:21 PM   #7
xtexsol37
xtexsol37's Avatar
Vehicle: 1988 Ford Mustang
Both will do the job. supercharger is cheaper and easier to maintain. My car was supercharged, and now I have an all motor car that will beat the old supercharger setup hands down.
I agree with the other guys, make sure you build the motor to handle the added power, if not you will have alot of problems. I have a hole in a Piston to prove it.
good luck with your build.
xtexsol37 is offline   Reply With Quote
Old 10-16-2009, 07:17 PM   #8
Sancho805
Sancho805's Avatar
first off... research the characteristics of each setup. then decide which characteristics you lean towards. that should help give you a better base of which questions to ask and which setup better fits your intentions.
__________________
'06 4.0 Stang :: Auto :: 3.73/T-Lok :: Aluminum D/S :: C&L Intake :: Bama Tuned
JBA H-Pipe Dual Exhaust :: JBA Shorty Headers :: GT Anti-Sway Bars w/ Poly Bushings
Sancho805 is offline   Reply With Quote
Old 10-17-2009, 11:49 PM   #9
legendlime05
2005 Ford Mustang
My Garage
Vehicle: 2005 ford mustang
most of what the decesion will turn out to be the goals of what youre trying to do. ever thought about spray?
__________________
legendlime05 is offline   Reply With Quote
40, 40l, cervini, charger, cost, forum, install, make, mustang, racers, street, super, supercharged, supercharger, superchargers, turbo, v6
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
