Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.0L V6 Specific General Discussion > 4.0L V6 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-18-2009, 11:27 PM   #1
SmokeStang08
Vehicle: 2006, Ford, Mustang GT
Default Engine swap cost
i found a mustang gt engine for $2500, lets say i buy this and want to use the automatic transmission already on my car with it. What else would i need and how much would i be looking at for a complete mustang gt engine swap?
__________________
2006 Mustang GT Torch Red
SmokeStang08 is offline   Reply With Quote
Old 10-19-2009, 06:15 AM   #2
Vehicle: 2006 Ford Mustang Pony Vert
You can't use the transmission in your V6. The input shafts are different so you will need a new transmission and drive shaft too. You also will need a new ECU for the V8.
__________________
Xcharger #020, J&M LCA/UCA; 8.8/3.55 & LPW cover; Dual GT500 take offs. Black bullitts. Shaftmaster aluminum DS. PB: 13.60 @ 100+ juiced - Xcharger: 13.42 @ 101
JimC is offline   Reply With Quote
Old 10-19-2009, 03:27 PM   #3
07 Stang
07 Stang's Avatar
Take that $2500 and put it towards an X Charger or you can save up and just buy a used GT.
__________________
07 Stang is offline   Reply With Quote
Old 10-19-2009, 03:46 PM   #4
jimkaray
2005 Ford Mustang
jimkaray's Avatar
Vehicle: 2005 Ford Mustang Coupe
With out a complete list of what is needed your best bet is to buy a whole wrecked car so you can salvage what you need and sell off the rest. Off the top of my head you'll probably also want/need: the GT radiator & fan (up & lower hoses) front springs and brake rotors (w/ the caliper brackets), not sure if the brake booster & proportioning valve are different, GT sway bars, wiring harness if it doesn't have it, probably the motor mounts as well.
__________________
4.0L, 5-Spd Stk, VMP MAF/CAI/93oct N2O Tune, T-Lok, Shorty Headers, FRPP Dual Exh kit, 18" Bullitts, CF Hood, Rr Louvers, SS Gen 1 Frt Cover, SHR Honeycomb Panel. ZEX N2O - 100 shot bests: 1/4mi ET 13.495 /MPH 103.95.
jimkaray is offline   Reply With Quote
Old 10-19-2009, 04:08 PM   #5
ODDYSEY
4.0L Section Moderator
2007 Ford Mustang
ODDYSEY's Avatar
I looked into this option before I put in my x-charger...
Option 1: Shop Installed
10k-20k is what I was quoted from 3 different shops.
Option 2: Self Installed
I did alot of research and the price was still above 5k to do it self installed and that was the total before I factored in costs like brakes, springs/shocks (already had) etc.
Option 3: X-Charger...
This is the option I took. $5k and I was done with gauges and extremely happy.
There are guys who have bought entire wrecked cars and done the swap, but they did it themselves, and there is alot more involved than just swapping engines.
__________________
V6 of Fury! - X-Charger #101 - HI-PO Plus 2.8 | FRPP GTA's | FRPP 3.73 & T-Lok | FRPP springs | Tokico D-Specs | BMR Panhard | Razors - 18x9 | Nitto 555's | Auto Meter - Nexus gauges | Shaftmasters aluminum driveshaft | TCI ratchet shifter | Moroso tanks | UPR catch can | and more...
Click here to view the V6 of Fury!
ODDYSEY is offline   Reply With Quote
Old 10-19-2009, 04:29 PM   #6
SmokeStang08
yeah i think ill just go with the X charger
__________________
Old 10-19-2009, 07:10 PM   #7
Sancho805
Sancho805's Avatar
Quote:
good idea.
__________________
'06 4.0 Stang :: Auto :: 3.73/T-Lok :: Aluminum D/S :: C&L Intake :: Bama Tuned
JBA H-Pipe Dual Exhaust :: JBA Shorty Headers :: GT Anti-Sway Bars w/ Poly Bushings
Sancho805 is offline   Reply With Quote
Old 10-19-2009, 07:43 PM   #8
Torch_Vert
2005 Ford Mustang
Torch_Vert's Avatar
An X-Charger is also an easy 6-8 hour weekend install requiring only hand tools, You can't say that about a V8 swap.
__________________
2005 Mustang 4.0L V6 'vert
X-Charger S/N 004 (First X-Charged manual, First X-Charged 'vert)
Torch_Vert is offline   Reply With Quote
Old 10-19-2009, 08:17 PM   #9
JCON
2005 Ford Mustang
Vehicle: 2005 Mustang V6 Convertible
take that and the amount of swapping and then add it to what you can get for your V6 and you can go buy a GT.
__________________
DeMolet CAI w/ Tune
Single GT Manual Take Off
JCON is offline   Reply With Quote
Old 10-20-2009, 03:35 PM   #10
Full Throttle
2005 Ford Mustang
Full Throttle's Avatar
if your gonna do an engine swap why stop at the GT v8, put in a crate motor or shelby 5.4
Full Throttle is offline   Reply With Quote
05, 40, 46, 54, cost, engine, ford, hbody, mustang, shops, swap, v6, virginia
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
