How much psi are you putting out with that 2.8 pulley? What brand water/meth system do you have?
It's running about 10psi, The water meth is a Bamachips Wet-X rig (Cooling Mist based)
I'm also running 90mm idlers for more belt wrap, a custom aluminum 2.8" pulley with antislip grooves and indexed NGK TR6 plugs with a Screamin' Demon coilpack. The aluminum flywheel and driveshaft help too.
