MustangForums.com
MustangForums.com (http://mustangforums.com/forum/index.php)
-   4.0L V6 Technical Discussions (http://mustangforums.com/forum/4-0l-v6-technical-discussions-66/)
-   -   4.0 Engine difference between 05-09 (http://mustangforums.com/forum/4-0l-v6-technical-discussions/627864-4-0-engine-difference-between-05-09-a.html)
95SHO 01-01-2011 09:18 PM
I am trying to install a 4.0 motor in my 2001 Explorer, but I am running into trouble regarding the felx plate. When did Ford changethe flex plate in the Auto 4.0 Mustangs. I thought everything was the same from 05-10. I read some where that there might have been a design change concerning the strater, flex plate and torque converter in 2008. Any truth to this??
Ahiodsohi 07-24-2011 01:33 AM
This thread may be super old and all, but I'm going to post what I know for the benefit of people searching this topic in the future (I came to this thread via Google search, for instance).
During a swap of a tranny and torque converter from an '05 into my '07 (long story, it was a straight OEM replacement for troubleshooting purposes), I found that the t/c and flexplate designs had changed between those years. The four nuts on the t/c were both a different size ('07 used a 1/2" socket, '05 was a 15mm socket, neither nut fit the other year t/c), and spaced differently (see pics below). As a result, the holes in the flexplate are also spaced differently.
'05 torque converter:
http://img190.imageshack.us/img190/8407/83296839.jpg
'07 torque converter:
http://img818.imageshack.us/img818/7017/62668966.jpg
For clarification purposes, both sets of parts came from '05-'09 4.0L V6 Mustangs with automatic transmissions.
MustangFirstCar 07-28-2011 01:12 PM
As I understand it the 05-06 were the same, and then they changed it for 07-09.
