Old 10-23-2015, 03:23 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Powertrain Guides
Print Wikipost
How-To 05 V6 Throttle body coolant bypass
Old 03-29-2011, 02:42 PM
2005Redfire6
2005Redfire6's Avatar
Originally Posted by obxdude018
Just did it only took like 10-15 mins to do, now nothing but cold air
Let me know if you can feel a difference!
2005Redfire6 is offline
Old 03-29-2011, 03:08 PM
obxdude018
obxdude018's Avatar
I would say there is a difference if not noticeable, but just based upon physics, for the fact that the air temperature inside the throttle body will be much cooler now. I have only driven it for a few miles since I did it so it was hard to tell.
obxdude018 is offline
Old 03-29-2011, 05:22 PM
amustangrocks
amustangrocks's Avatar
i did this bi pass a couple years ago. it didnt really make any difference that was noticable. but like was said, removing heat sure didnt hurt. those lines are not needed for any reason. however, it makes removing the tb to clean so much easier, its well worth doing. at some point i`m just gonna replace the metal tube assembly for a 06 that doesnt have the tb coolant lines and eliminate the bi pass all together.( but that part is not cheap) ididnt bother making a loop to go under the tb. i used the longer hose and just turned it around and clamped it onto the tubes.
amustangrocks is offline
Old 03-30-2011, 06:59 AM
2005Redfire6
To me it feels like the car stays responsive like the first few minutes of a cold start and doesn't seem to get that bogged down feeling.
Old 03-30-2011, 07:15 AM
Nuke
Nuke's Avatar
I'm glad you did it. Those hoses had those nasty red lines running along them. It may have spread to your muffler bearings...
Good write-up and pics.
Nuke is offline
Old 03-30-2011, 07:20 AM
2005Redfire6
Yea I know! One of them had a leak and was starting to pull fluid from my blinker fluid reservoir...
Old 05-10-2011, 09:26 PM
Alec
Alec's Avatar
Soo I finally took some initiative and got this done today. Very good write up Eddie, a lot easier than I thought it would be. Haven't noticed any significant differences, but we'll see over time. Definitely seems like it would keep things cooler, which is a plus
It gets pretty cold up here in PA, is that a concern?
Alec is offline
Old 05-12-2011, 09:22 AM
2005Redfire6
No sir, it gets in the teens here so I wouldn't worry about it. Plus all the other 06+ 4.0's don't have heated TB's and they have no issues!
And thanks!
Old 05-12-2011, 09:34 AM
Alec
Alec's Avatar
And thanks!
True, that's what I was thinking. Just wanted to double check.
Can't say I've noticed a performance increase/decrease but when put on cold the air seems to be a little cooler. It was always hot/warm even when on cold
Alec is offline
Old 05-12-2011, 11:21 AM
2005Redfire6
Thats odd lol. I think you will notice more of a difference when you have been driving the car for a little bit then just your average run around the block.
Quick Reply: How-To 05 V6 Throttle body coolant bypass
